How do I start tuning my transmission? I don't see it on the calibration menu
It is on a separate controller. Just as how you downloaded the file out your truck (green arrow tab) do the same thing except pick the allison 5spd or 6 spd controller. Be careful playing with the trans. You can play with shift points, but shift times ( as in how fast it shifts from gear to gear) you do not need to play with. The alli will learn out of it normally and your just asking for a hangup if you do so. Good luck
Thanks alot man
