Results 1 to 7 of 7
Thread: No device connected?
    Jan 2011
    Default No device connected?
    im trying to get my v2 to work on my new laptop. Ive downloaded both 7.5 and 8, ive ran the updates to the software. I am able to read my engine with the v2 but unable to flash with it. Im now trying to update my firmware and i get a no device connected error.
    what am i doing wrong? thanks
    Oct 2004
    Have you just updated from the 2.04.x firmware to 2.05.x and later? If so is your device asking repeatedly to upgrade licenses (or similar)? If so please email me (support@efilive.com) an I can email you some instructions to resolve the issue (more than likely). If it is the issue I expect it is due to first not having updated to 2.04.72 firmware as described in the firmware update documentation.
    Andrew
    EFILive Crew
    Jan 2011
    Ok. so yes my firmware does need an update.. its a 2.04.60.
    I followed the steps listed in the documentation then i get this error.
    Oct 2004
    When usign the old 'EFILIve Firmware Programmer' application you nned to hold down the CTRL key on the FlashScan V2 keypad while plugging in the USB cable. This puts the device in to 'deadpoll' mode. Hopefully that will allow you to perform that initial update to 2.04.72.
    Andrew
    EFILive Crew
    Nov 2006
    That's some old firmware.
    LC-1 WBO2
    Jan 2011
    Quote Originally Posted by Tordne View Post
    think i got it working. thank you
  1. Not Connected message
    By 920codyroad in forum Gen III V8 Specific
    Last Post: December 15th, 2009, 05:45 PM
  2. V2-device not recognized
    By zacksfoam in forum FlashScan V2
    Last Post: August 14th, 2009, 06:56 PM
  3. V2 acts up with the Serial connected
    By nonnieselman in forum FlashScan V2
    Last Post: November 18th, 2008, 02:25 PM
  4. Replies: 1
    Last Post: October 16th, 2008, 11:01 AM
