Results 1 to 9 of 9
Thread: AutoCal WBO2 - Just an idea
    Nov 2007
    Default AutoCal WBO2 - Just an idea
    I know there was much controversy about the AutoCal not having a serial input.
    So I was browsing the Innovate web site and found this
    Software and Hardware Integration Tools
    LogWorks 3 Software Developer's Kit
    The Innovate MTS (Modular Tuning System) SDK makes it easy for Window's programmers to
    input data from Innovate products directly into your application. The SDK "hides" the complexity
    of the MTS serial protocol, allows you to write device-independent programs, be future-device
    compatible, and work seamlessly with LogWorks 3. Download here.
    I know you guys are super busy but it would be cool if the data could be streamed
    from LogWorks to EFI Live.
    Thanx
    -Justin
    Nov 2006
    WBO2 or another analog device can be logged though the EGR or A/C input in the PCM.
    LC-1 WBO2
    Nov 2007
    I know that is part of old thread.......thanx anyway
    Jul 2003
    Quote Originally Posted by L31Sleeper View Post
    Thanx
    -Justin
    That was what I suggested on another thread.
    Nov 2007
    OK so how do we get'er done ??
    Oct 2004
    At the risk of being a downer I don't think this is something that will be on the to-do list anytime soon. The AutoCal (rightly or wrongly) was designed and specified to not include a serial (or analogue) wideband connection. Please also consider that while Innovate is likely to represent a reasonable proportion of what customers are using it is just one of many wideband controllers that are out there.
    Andrew
    EFILive Crew
    Nov 2007
    Andrew you have NOT hurt my feelings.......I just figured I would share the info I found
    Oct 2004
    Thank goodness
    Andrew
    EFILive Crew
    Jul 2004
    It would be no harder and probably easier to just support the Innovate serial data stream directly. It's well documented and while I have issues with the layout, it works just fine. But, Autocal was not designed for that purpose and I'm guessing it's not likely going to happen.
    Ira
  1. AutoCal WBO2
    By L31Sleeper in forum AutoCal
    Last Post: January 2nd, 2011, 06:16 PM
  2. Installing wbo2
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2008, 11:20 AM
  3. Dash idea
    By GMPX in forum General
    Last Post: May 20th, 2005, 12:45 PM
