Results 1 to 7 of 7
Thread: Do's and Don'ts
    Oct 2009
    Default Do's and Don'ts
    Hey guys.
    I just got a new converter that i'm going to put in when the weather breaks. The converter is a Yank TT2600. I have been searching all over trying to find out how to tune for the new converter, and what kind of things to look for when and after it's tuned.
    In other words. What are the does and do not's of TC tuning. I wanted to do a full VE prior to the converter swap so I know my af's and fueling and everything else is correct. I then wanted to work on my tc part prior to the install to have a good base.
    The trans is a fully built 4L65E with TM removed, and line pressures tweaked a little. Also the motor is cammed, and I have read that it might make the verter come in and out of lock up due to misfires, so what would I have to do then? Thanks for your time.
    Senior Member MyM8V8's Avatar
    Aug 2008
    When I installed my CircleD 4200 stall, there were no issues at all. Didn't need a crank relearn either, just worked out of the box, don't know how wild your cam is though???. Difference here is that I already had my PCM and TCM tune optimised . You only have a 2600 so I don't think you'll have any issues either (depending on that cam and how good the tune will be), as Joecar said to me, install it and try it. Search for the relevent threads, they're in here. Good luck, I'm sure you will enjoy the stall.
    I'd say get your tunes sorted first though. Post up your spec's including cam.
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    you may have to adjust B4315 to B4320 if it try's to stall when coming to a stop.
    slow down the decay rate a bit
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Aug 2008
    Yes you are right, I forgot, I did have that problem too, but sorted quickly.
    Off topic. Just noticed your sig'. I've got some nice wine from your town, it's called Ring Bolt. Long way to come here though. Very nice!
    Yes that right, the Margaret River wine area is known for some of the world's best premium wines.
    Pity i'm not a wine drinker
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Aug 2008
    Quote Originally Posted by gmperformancecentre View Post
    I found out about that wine when I went out for a meal with my cousin in Surfers. Funny thing is, you can buy it over here for half the price we paid over your way???.
    Anyway, we digress!!
    yeah that sounds right
    i was in new zealand a couple years ago and also notice that margaret river wine's are least there then here
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
  1. Pids don't respond!
    By aleco99 in forum Custom Operating Systems
    Last Post: January 10th, 2008, 05:30 AM
  2. I don't know ?
    By Chevy366 in forum Tips and tricks
    Last Post: May 15th, 2007, 03:07 PM
  3. Don't stare at his too long...
    By joecar in forum Lounge
    Last Post: August 14th, 2006, 11:37 AM
  4. Don't try to download firmware to your LC-1
    By joecar in forum Tips and tricks
    Last Post: February 2nd, 2006, 05:11 PM
  5. Don't Give up on us Gassers !
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 21st, 2006, 01:10 AM
