im trying to turn the sercuity off the pcm and efi live wont let me hook and tune it.. i tired all the pcm selection u have available.. help! thanks in advance!!!
Send the full VIN for the vehicle to me (support@efilive.com) and I can confirm if we support it or not, and if so what ECM selection you should be making.
Andrew
EFILive Crew
thanks i just sent the vin to you!
We don't have any 3.1 litre vehicles listed on our supported vehicles page so I'm going to guess that it is not a supported platform. The VIN you emailed also lists OS numbers that are not recognised by the software. Is the Grand Am you're trying to flash a V6 (unsupported) or LS1 V8 (supported)?
Andrew
EFILive Crew
Its a 3.4 v6
The only 3.4 litre V6 vehicles we support are the 07-09 Chevrolet Equinox and Pontiac Torrent, both are using the E38 ECM controller. I think it is just a case of your vehicle simply not being supported by EFILive.
Andrew
EFILive Crew
well it looks like the duramax lly and ls198-whatever ecm.. is there anything we can use then to get the sercuity turned off?
A lot of the early PCMs "look" the same but they are different internally, such that each needs to be specifically supported. There is nothing you'll be able to do with EFILive as it is not a supported controller.
Andrew
EFILive Crew
ok. well humm.. any ideas for help? do u guys have any system that would work? or it is all the same?
any help?
