Whats the best WB02 to use with my V2? getting ready to buy one and would like some input? thanks.
2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
1984 CJ7 powered by a 2000 LS1. 4L60E.
2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
2003 Jetta TDI,
1986 K10 LQ4/4L80E
Id suggest either Innovate's LC1 or NGK AFX. I have both and they're great, the only thing I dont like about the NGK is the huge screen for AFR. But it's nice when you have it on a vehicle without a gauge or V2 hooked up (used it on an 08 Jetta). Plus to the LC1 is the serial interface you can hook directly into you V2.
i agree get one with serial interface that way youre not fighting with ground off sets
97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
stock sucks
Ok thanks for the help.
2003 Jetta TDI,
1986 K10 LQ4/4L80E
I like the LC-1 to serial with a Null Modem adapter for the serial connection! This way you can always disconnect at Null Modem and connect serial or serial USB to laptop to recalibrate the LC-1 controller.
I got a AEM UEGO gauge with the outputs in analog to the EFILive. No problems and simple hook up
