Page 66 of 75 FirstFirst ... 16566465666768 ... LastLast
Results 651 to 660 of 743
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
  1. #651
    No worries...
    post some screenshots of the steps you did...
  2. #652
    May 2011
  3. #653
    May 2011
  4. #654
    May 2011
    i took the above maps created by the calc ve tutorial but i think i must have something wrong in the pids or the maps... can any of you view my created maps through my log i posted?
  5. #655
    Something is wrong with the values of the pid EXT.WO2LAM1, they should range from 0.5 to 1.5.
    Which wideband are you using (did you say LM-2)...? Something is wrong with it.
    Can you log it's 0-5V analog output to see if it correlates...?
  6. #656
    May 2011
    yes it is the lm-2. i am trying to trouble shoot that issue. do i need to be looking for a problem with the wideband controller itself or something incorrect with how i have my scan tool setup. sorry i feel so dumb on this. i am not understanding how i am getting wideband data on to the scan tool yet that one pid is showing what it is.
  7. #657
    May 2011
    My calc.vet setup on the scan tool, something is not right. And when I click on the calcpids in the beginning of this post an error comes up saying that calcpids is an invalid efilive file
  8. #658
    I just clicked on the calc_pids.txt link at the beginning of post #1 and it opened ok in Windows Notepad...
    when you click on it you want to save it to your PC (i.e. do not open in as an EFILive file).
  9. #659
    May 2011
    okay... duh its been a minute since ive been at it. it kept opening it with efi live...
  10. #660
    Jul 2015
    i need help i have went thru this post on calc ve and my question is i run sd mafless and i always disable ltft and stft and tune my ve i use a map that shows me the wideband afr rpm vs map kpa and then i go cell to cell and make adjustments i would love to use this method im just curious what script i need and pids to use i use a lm2 in serial . i also see auto ve is a option but the write up uses analog wideband im sure i could switch to analog but there has to be a way to do it in serial thanks in advanced im a rookie
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
