Page 68 of 75 FirstFirst ... 18586667686970 ... LastLast
Results 671 to 680 of 743
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
  1. #671
    Quote Originally Posted by steve40 View Post
    Is this meant to replace autove? Or does this assume the car is close in tune?
    No... it replaces AutoMAF (but using both WB and LTFT), and calculates a VE table from it.
  2. #672
    Jul 2005
    maybe the wrong spot for asking, but is there a preferred way to tune a car now. i've been out of a car for years now and just got mine fired up and started with the autove, that's what i used last time. this is for a car that is well, decently far off.
  3. #673
    You use the mdthod that works for you and that you are comfortable with.
    A large part of tuning is knowing when to use which method, and to understand the method (and its implications) sufficiently well to get good results.
  4. #674
    Aug 2016
    Hi guys, I'm fairly new to the EFI tuning world. I'm tuning my slightly modified 2004 GTO, and I'm having issues with CALC.VE and CALC.VET. I've attached my latest log, tune, and calc_pids files. Whenever I paste (with labels) my new VE values (in g*K/kPa, or %) I get some really weird values. Any idea what I might be missing here, or is my factory VE table off this much? Any help would be great!
    Garrett_GTO_tuned_20160802_1.ctz
    GTO_August_5_2016_1.efi
    calc_pids.txt
  5. #675
    Can you post screenshots of what is happening...
    I now use Calc.VET instead of Calc.VE: Calc-VET-correcting-MAF-and-calculating-VE-(in-single-log)
    Try the attached tune.
    Hints: use more throttle, try to make smaller motions on the throttle.
    Question: did you change your MAF plumbing air duct...? Post pics.
  6. #676
    Aug 2016
    Thanks Joe!
    I've attached screenshots of my B0101 and B5001 before and after using Calc.VET, as well as the tune with these changes. I started with Calc.VE a few days ago, but after I got wonky results (similar to what I see with Calc.VET), I found this thread. The two big things that I'm unsure of are the spikes in the B0101 table, and the drop in the B5001 table. These are following the first post's tutorial, and making sure to apply the Calc.VET filter.
    I'll give your tune a shot and get some drive time logged. Should I shoot for more RPM, or just try to get more load on the engine? By smaller motions, do you mean accelerate more slowly and get to higher RPMs, then hold it with steady throttle input?
    I have changed my induction, I've attached a picture of that as well. The main changes are an XAir intake and fast acting IAT. I do have aftermarket headers (short) and JBA mid pipes (catted).
    After:
Name:	B0101 After.JPG
    Before:
Name:	B0101 Before.JPG
    After:
Name:	B5001 After.JPG
    Before:
Name:	B5001 Before.JPG
    Induction:
    Tune with Calc.VET logged updates:
    Garrett_GTO_tuned_20160805_1.ctz
    I looked through your tune, thanks for running through that! I think I understand what you did. It looks like you took out the PE enable delay, made the PE modifier 0.85 across the board, and modified the TPS % for PE enable. I assume the B3615 modifications are based on experience?
    For the B0101, did you mainly smooth the lower RPM "dip" it had? I think that makes sense, I actually had an issue under higher load, lower RPM acceleration where the engine would lean out for a second or two. Did you do a decent amount of smoothing on the B5001 and lower it a bit? Sorry for all the questions, I'm an engineer and can't help it!
  7. #677
    Quote Originally Posted by pinstripebob View Post
    You need more load, and larger throttle opening... but try to keep throttle smooth (less jerkiness), this is hard on the street... dragging hard on the brakes for a few moments will help increase load.
    After doing low RPM and seeing the trend in MAF, then edit MAF table to continue trend, and then do a high RPM log (but pay attention it does not go lean, i.e. want PE fueling to be 0.86 lambda (1.163) or richer (not leaner).
    Induction:
    I suspected your MAF duct had changed (see my comment below regarding B5001)...
    If the driver does not realize the PCM is in hot mode, then PE should still kick in as normal, there is no reason to hold it off.
    Yes, the trend was downward a bit, so I carried it up.
    No worries. Me too
  8. #678
    Aug 2016
    Alright so I loaded your tune and did some logging. I did three logs (really just two, the first was a quick spin around the block). I wasn't able to get some good time with high load/throttle opening. So today on my way to work, I used a stretch of fairly flat highway to log high load/throttle opening. I got a log there and one back. The log there seemed to give me pretty good data. It looks like my B5001 wants to come down a hair, and most of the data for B0101 wants to bump it up a bit. Can you take a quick look and make sure I'm on the right track with my thinking? I've attached my later two logs, and a modified tune based off the first log.
    First log:
    GTO_August_8_2016_1.efi
    Secong log:
    GTO_August_8_2016_2.efi
    Tune:
    Garrett_GTO_tuned_20160808_1.ctz
  9. #679
    Jul 2005
    just a quick question setting up the calc.ltftben {b5001} map, why is engine rpm used in the column tab?
  10. #680
    May 2014
    Basically its just a placeholder to get the map to fill in that column. Pretty sure you can use almost any selected PID, but RPM for sure works.
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
