Page 72 of 75 FirstFirst ... 22627071727374 ... LastLast
Results 711 to 720 of 743
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
  1. #711
    BADCADDY,
    Here is the E67 calc_pids.txt file, rename it to calc_pids.txt, move it to folder C:\Users\<you>\Documents\EFILive\V7.5\User Configuration
    then start the scantool, select the pid CALC.WO2BEN and/or CALC.SELBEN, and then on these same pids go rightclick->More Info to see which other pids need to be selected also.
    In your tune file, table B0179 is all zeros, which I was not expecting, so in the calc_pids.txt you will see that the pid CALC.B0179 looks up zeros... when you get table B0179 populated with better values, we can update the pid CALC.B0179 with the same values.
  2. #712
    Oct 2016
    Hey Joe,
    Doing some logs tonight and will post them up, just double checking PID list looks good ?
  3. #713
    replace SAE.TP with GM.ETCTP
    and rest looks good.
  4. #714
    Jan 2007
    I have a dumb question if this is allowed. Is it suggested/recommended to run this process with STFT only?
  5. #715
    Yes, you could do it that way if you wanted...
    ( you could do it using LTFT, or STFT, or LTFT+STFT )
    the reason we chose LTFT is that LTFT is the trend of STFT.
  6. #716
    Jul 2019
    Hi there
    I have been following the instructions to preform CALCVET but no where in the instructions does it say how to run the log file to effect changes to the tables I cut and pasted from my tune.
    I must be missing a common unstated task?
    VERY NEW TO EFI LIVE so I no nothing about how to do this so every step needs to be specified
    Thanks for your patients
    D
  7. #717
    Feb 2019
    My hard drive recently crashed and I had to reinstall EFI live. I'm having trouble with the PID selection in my scan tool now. I copied the Calc Pids into their proper location, but a bunch of other pids are now invalid. If I right click for more information, they do not tell me why they are invalid. Please see the screenshot and advise. Thanks!
    I apologize. I forgot to actually connect the flashscan to my controller. Seems to be fine now!
  8. #718
    Ok, you did Info->Validate Pids and now they are valid...
  9. #719
    May 2014
    Joe, here are the pics in the OP without the photobucket watermark nonsense. Use them to update the OP if you'd like and I think it would be wise to host them directly on the website so it's not reliant on an external source.
    https://i.imgur.com/jMQVZOP.png
    https://i.imgur.com/V7Es9Se.png
    https://i.imgur.com/HpGMzPO.png
    https://i.imgur.com/9jqe07K.png
    https://i.imgur.com/jlDG03K.png
    https://i.imgur.com/M0diu80.png
    https://i.imgur.com/Kwupwj8.png
  10. #720
    Sorry, I have been out of town working, and now I'm interviewing for a new job.
    I'll take a look at those over the next few days.
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
