Page 59 of 75 FirstFirst ... 949575859606169 ... LastLast
Results 581 to 590 of 743
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
  1. #581
    Senior Member djv86's Avatar
    Nov 2014
    Whenever I apply the filter as listed in page 1 all the data becomes invisible any ideas ?
  2. #582
    Quote Originally Posted by djv86 View Post
    Post screenshot of your filter and pre-filter map (data).
  3. #583
    Nov 2014
    I think I had it say "include" instead of "exclude"
    All thought the second I save the vet datalog and click on it again the map readings go way out of Wack.
    Like 100kpa while logging they read accurately then all of a sudden they turn into reading that are wrong so I have to change the data on the map into the ven instead of vet to make any type of accurate change
  4. #584
    Post your log file and your calc_pids.txt here...
    which V7 software build version do you have (go Help->About)...?
  5. #585
    To help with screenshots see post #10 here: Hosting-an-Image
    I want to see your filter...
  6. #586
    BTW: in the map properties, on the Data/Col/Row tabs checkmark Show Units and click Save.
  7. #587
    Nov 2014
    I'm using the feb2015 programs
  8. #588
    Nov 2014
  9. #589
    Nov 2014
    i think i figured it out.. my brother installed the wideband bung POST cat convertors and under cruise reading was fine but under WOT or heavy load the wideband would become extreme lean and gauge would give inaccurate readings
  10. #590
    Feb 2012
    Post-cat positioning of your wideband should not cause it to read lean under load.
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 05:26 PM
  2. OLFA table vs. Custom OS A0008 table
    Last Post: January 6th, 2007, 05:25 AM
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 04:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 02:36 PM
