Whats the forumla to figure up cylinder volume. Im working on a 441ci lsx I guessed for now at 856.. I know a 408 ci is 836..
Anyone willing to help?
I calculate that 441 ci = 7.2267 litres. 7.2267 litres / 8 = 0.9033375 litres per cyl.
Andrew
EFILive Crew
LC-1 WBO2
Thanks guys. Saving that speadsheet to my desktop!
I just saw this thread could any body tell me why i should change the cylinder volume ?
i already finished the AutoVE tune should i do it again ?
my car origenaly has LS1 but now it has 408ci engine
EFILive Tuner
http://www.wolframalpha.com/input/?i...ches+to+liters this is the easiest way to deal with all unit conversions.
Why do it? Because it gets used (not on all model/years, but most pre E40 ones) to calculate airmass. If you've tuned your entire VE with a wrong value (I'm guessing the default 0.708), then you need to multiply your entire VE by the ratio of old volume vs new volume. So if the new is 0.9033 and the old is 0.708, the ratio is 0.784. So take your (ridiculously high) VE table and multiply it by 0.784 and now you're closer to reality. That's it.
That was one of the issue with a car i have been working on just found it, found a recipte where it has a different crank, rods and pistons larger than 6.2L that should make thing come more inline with normal.
David McLain
www.etdrag.com
