Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: LC-1 wiring question..
  1. #21
    Senior Member Tydriver's Avatar
    Mar 2005
    Quote Originally Posted by Tydriver
    Dayang, dont I look like a big dummy !!! Thanks for the heads up.. I appreciate all the information, I already checked with Innovate Motorsports on the sensor before I posted and was surprised it was $79+ shipping.. Hence the reason I didnt just order it online from them.. I was going to crawl under the truck and get the number off the sensor but thats cool.. I never figuired they'd refer you to their competition..
    Thanks again for all the help..
    ---edit---
    I ordered this sensor locally from Napa Automotive, the part is all over the place price wise from the local stores, (Autozone,Napa, Advance Auto etc).. I found it for $45 from my local Napa they have to special order it but beats $80 from Innovate, it was a toss-up dealing with that place you mentioned since the pricing woulda worked out about the same in the end. I just chose to support my local guy instead..
    Thanks again IRA, I appreciate the information.. Anyone wanting to order the Napa Part the BOSCH part # is 17014 and the Napa# is BSH-17014.
    Todd
    1993 BMW 325is <- For Sale
    2003 Silverado LS 4x4 <--- you want to autocross what?
    2005 Avalanche 5.3L LS(EFI Live tuned) <-- my gas hog running on e85 3+ years now
    2012 Subaru Outback (wife's daily)
  2. #22
    Member bK's Avatar
    Mar 2004
    LC-1 is wired in and working perfect..... Well almost perfect it's got the slightest ground offset of 0.03. I've worked this out from changing analogue 2 output to a flat line of 2V at 10:1 and 20:1 AFR. The reading I get from the Flashscan is 1.97V.
    So to get my the calculation for correct Wideband AFR to work perfectly I need to modify the SAE_GENERIC.txt from:
    ({EXT.AD1}*3)+7.35 to
    (({EXT.AD1}+0.03)*3)+7.35
    Does this sound correct? I’ve done the maths in a spreadsheet and calculates spot on
    The LC-1 manual was excellent source of information but if there is a revision can there be a mention to the ground offset please?
    Brett
    Chassis by Holden
    Engine by Chev
    PCM modified by Flashscan
    Cam by Comp Cams
  3. #23
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    BSH-17014, from NAPA? Is that a wideband sensor? If so, that's my next purchase, especially for $45.
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
  4. #24
    Mar 2005
    Quote Originally Posted by eboggs_jkvl
    Elmer
    That is for the O2 sensor yes.. You obviously still need the LC1 box from Innovate.
    Todd
  5. #25
    Apr 2004
    OK, fog is coming back in the harbor...
    I need the sensor, AND that gizmo from innovate? Doesn't the sensor simply wire in to my EFILive scanner/programmer interface with the plugs that came with the V7 Flash/Scan Personal kit?
  6. #26
    Fog's nothing, how about when core dumps... several times already today...
    The WB sensor plugs into the WB controller module;
    the WB controller module has analog outputs for NB and WB signals.
    the whole thing (WB sensor + WB controller module) is the "LC-1" that comes from Innovate (altho "LC-1" is really the WB controller module).
  7. #27
    Jun 2006
    Is a $200 price tag on the LC-1 set w/o display module a good price, or are there any places that have them cheaper than that?
    http://www.dynotunenitrous.com/store...?idproduct=169
  1. e fan wiring and control
    By kostelacd69 in forum Gen III V8 Specific
    Last Post: July 22nd, 2009, 08:36 AM
  2. Plx wiring help
    By blazinblue in forum General (Petrol, Gas, Ethanol)
    Last Post: September 28th, 2008, 06:53 PM
  3. Question about lc1 wiring hook up
    By esco35m in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2007, 05:26 AM
  4. Need Help Wiring up Sm-AFR to V2
    By Chalky in forum General
    Last Post: March 11th, 2007, 04:36 AM
  5. wiring
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2006, 05:05 PM
