Results 1 to 10 of 20
Thread: DSP5 question
    May 2009
    Default DSP5 question
    Have followed the instructions and still something is wrong. Getting four volts from switch per scan tool pid.
    THis is what the tune says in efi upgrade OS-
    The currently loaded *.tun/*.bin file operating system does not support custom operating system upgrades using this option
    What am I doing wrong?
    06 LBZ CCSB
    A few bolt on's!
    Oct 2004
    What software version are you using? You could send your file to me (support@efilive.com) and I could see if it works for me.
    Andrew
    EFILive Crew
    May 2009
    V7.5.6 build133 and suggestions
    06 LBZ CCSB
    A few bolt on's!
    May 2009
    I also try now to make another dsp5 tune and it says this upgrade cannot be undone. on all tunes?
    06 LBZ CCSB
    A few bolt on's!
    Oct 2004
    The DSP upgrade cannot be undone. You need to save your stock or current file first and then save the DSP as a new one.
    Andrew
    EFILive Crew
    May 2009
    I have all my files saved to other computers. 1st dsp tune was base a race tune. Next dsp tune I tried to make it sad this?I can't even get the first one to work?
    06 LBZ CCSB
    A few bolt on's!
    Oct 2004
    You've lost me now! Does the software let you upgrade your calibration to a DSP5 or not? You only do the DSP5 upgrade once and then change the 5 tunes. What actually happens when you do the DSP5 upgrade is that there are significant changes applied internally to the operating system (which is why it can't be undone). You don't need to apply those changes repeatedly just to change the #1 - #4 positions.
    Andrew
    EFILive Crew
    May 2009
    Sorry, yes I have one dsp tune that is completely done. But in upgrade OS it says what is stated in post 1. I've read the direction a few times and seems easy. Just not working for me.
    06 LBZ CCSB
    A few bolt on's!
    Oct 2004
    Are they both the same operating system, or are they for different vehicles? Can you send the problem file to me (support@efilive.com)?
    Andrew
    EFILive Crew
    May 2009
    my truck. on its way.
    06 LBZ CCSB
    A few bolt on's!
  1. DSP5 back to Stock Question
    By Intel in forum General (Diesel)
    Last Post: July 9th, 2012, 05:04 AM
  2. DSP5 Output Question
    By JrTuner in forum Duramax LB7
    Last Post: August 25th, 2010, 01:25 PM
  3. Dsp5
    By L31Sleeper in forum General (Diesel)
    Last Post: July 8th, 2010, 10:05 AM
  4. dsp5 question
    By dirtymaxx03 in forum Duramax LB7
    Last Post: December 21st, 2009, 06:23 AM
  5. Dsp5
    By turbo lcc in forum Duramax LLY
    Last Post: March 17th, 2007, 08:46 AM
