Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Response $31: "Request Out of Range" when changing VIN on '00 Escalade
    Jan 2011
    Default Response $31: "Request Out of Range" when changing VIN on '00 Escalade
    So all I'm trying to do is change the VIN on a '00 Escalade PCM but I'm getting this response $31 error. I changed many VIN on many 99-08 LS1 PCMs ('01 Tahoe, '02 Silverado, '05 Silverado) and never had a problem but now this 98-00 Vortec PCM connects and seems to be all good and can read the PCM's current VIN but when I try to change it I get the error. Here's the error report:
    Error report generated by EFILive at 23:09:19 on Jan 19, 2011
    Error code: ERR_RESPONSE/5
    Response $31: "Request Out of Range".
    EFILive Version: 7.5.6 (Build 133)
    Platform: Windows NT
    Version: 6.0 (build 6002)
    Processor type: Pentium 2600MHz
    Directories
    Temporary Cache: C:\Users\Matt\Documents\EFILive\V7.5\Temporary cache
    Logged Data: C:\Users\Matt\Documents\EFILive\V7.5\Logged data
    Customers: C:\Users\Matt\Documents\EFILive\V7.5\Customers
    Configuration: C:\Program Files\EFILive\V7.5\Configuration
    Exported Data: C:\Users\Matt\Documents\EFILive\V7.5\Exported data
    Images: C:\Users\Matt\Documents\EFILive\V7.5\Images
    Sounds: C:\Users\Matt\Documents\EFILive\V7.5\Sounds
    Maps: C:\Users\Matt\Documents\EFILive\V7.5\Maps
    Pids: C:\Users\Matt\Documents\EFILive\V7.5\PIDs
    Virtual Dash: C:\Users\Matt\Documents\EFILive\V7.5\VDash
    Print Reports: C:\Users\Matt\Documents\EFILive\V7.5\Print reports
    Bug Reports: C:\Users\Matt\Documents\EFILive\V7.5\Bug reports
    Connected: No
    Com port: 0
    Com setup: EFILive FlashScan V2.5: USB
    Requested baud rate: 115200
    Cable id: 7
    Cable code: FlashScan V2
    Cable desc: EFILive FlashScan V2
    Cable version: 2.6.12
    Cable Firmware date: 20090607
    Cable model: FSV2
    Cable Serial number: 003823256641
    Protocols: 0
    Protocol list:
    Auto connect: No
    Scan OBDII info: No
    Error retries: 1
    Retry delay: 10
    Message throttle: 0
    Most recently used VIN: 1GYEK13R1YRxxxxxx (Note: 1)
    PCM information
    Hardware Number: N/A
    Calibration ID: Unknown
    Serial Number: 40EYK3928186
    Operating System: 16265175
    Engine Calibration: 16259044
    Not used: 16259128
    Transmission Calibration: 16259128
    Not used: 16259197
    Fuel System: 16259197
    System: 16259247
    Speedometer: 16241186
    Operating System BCC: CDNH
    Stream-Slow scan mode: Supported
    Stream-Fast scan mode: Supported
    Maximum dynamic packets: 16
    Detected modules:
    $10="Powertrain Control Module (PCM)"
    Report ID: 1933831 (Note: 2)
    Notes:
    (1) The VIN sequence number is not required for this report and for your privacy it is NOT included in this report.
    (2)The report ID is a checksum of the report text and is used to verify the integrity of the report.
    Oct 2004
    Please update both your software and firmware versions and try again.
    Here are a couple of knowledgebase articles relating to software and firmware updates:
    - Software
    - Firmware
    Andrew
    EFILive Crew
    Jan 2011
    Still didn't work
    Error report generated by EFILive at 06:53:07 on Jan 20, 2011
    Directories
    Connected: No
    Com port: 0
    Cable id: 7
    Cable version: 2.7.4
    Cable Firmware date: 20101130
    Cable model: FSV2
    Protocols: 0
    Protocol list:
    Auto connect: No
    Scan OBDII info: No
    Error retries: 1
    Retry delay: 10
    Message throttle: 0
    PCM information
    Not used: 16259128
    Not used: 16259197
    System: 16259247
    Detected modules:
    Oct 2004
    Your V7 software hasn't been updated, it is still showing version 133. Could you please try and install the Build 139 version on our website?
    Are you able to scan/datalog the vehicle at all?
    Andrew
    EFILive Crew
    Jan 2011
    Ok I got that updated and still the same thing. I am doing this on a benchtop with a wiring harness from EFIconnection.com. I have never done any scanning or datalogging and I don't even know if I would be able to do that since the PCM is out of the vehicle. When I click on the change vin option, it is able to read the PCM's current VIN and puts that in the "Current VIN" field. Even if I clikc on "copy VIN" and "check Digit" then "ok" it still comes up with this error.
    Error report generated by EFILive at 21:28:21 on Jan 20, 2011
    EFILive Version: 7.5.6 (Build 139)
    Directories
    Connected: No
    Com port: 0
    Cable id: 7
    Cable model: FSV2
    Protocols: 0
    Protocol list:
    Auto connect: No
    Scan OBDII info: No
    Error retries: 1
    Retry delay: 10
    Message throttle: 0
    PCM information
    Not used: 16259128
    Not used: 16259197
    System: 16259247
    Detected modules:
    Jan 2011
    Ok so I just tried scanning which I have never done before. Since the PCM is out of the vehicle I just checked the battery voltage PID and it scans and comes up at 12.0 so I would have to say that yes, I am able to scan.
    When you posted the error reports, there should have been a whole lot of extra data that is not present in the ones that you posted. Can you post the entire error report after you get the error when trying to save the VIN.
    Use the [Save] button when the error report shows up, then attach the saved file to your post.
    To attach the file, click the [Go Advanced] button underneath your post.
    Then click the [Manage attachments] button to upload the file as an attachment.
    Jan 2011
    There we go, I guess that is probably a little easier, haha
    Jan 2011
    Any ideas yet?
  1. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  2. 12200411 retrofit, have efilive "VIN" question
    By rb1 in forum Gen III V8 Specific
    Last Post: June 2nd, 2007, 07:39 AM
  3. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
