Results 1 to 3 of 3
Thread: Can this software be used in marine applications?
    Aug 2008
    Default Can this software be used in marine applications?
    2008 crew cab LTZ, turbo back 4", EFI and some other stuff
    Nov 2006
    As long as the PCM is on the supported list.
    The hardware and software are not waterproof.
    LC-1 WBO2
    Yes, but not with MEFI 4/5. You have to run a regular GM production ECM/PCM (or GMPP E67) in order to use EFILive with marine applications. Personally Id never use the MEFI stuff when you can use a regular ECM/PCM and EFILive, much cheaper and more tables to adjust.
  1. Old Software...
    By MMLMM in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 19th, 2010, 07:05 PM
  2. Mercruiser Marine intake injectors
    By onegonewild in forum Vortec V6/V8 Specific
    Last Post: July 22nd, 2008, 11:21 PM
  3. 0411, marine intake and 4L80E
    By hquick in forum Custom Operating Systems
    Last Post: November 24th, 2007, 02:43 PM
  4. Marine Manifold and idle tune...
    Last Post: October 20th, 2007, 11:15 PM
  5. EFILive & Mercury Marine MEFI 3 ECM
    By Kleptow in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2006, 12:19 PM
