Hey guys. Is anyone using the A0010 timing pull vs KPA to pull timing for boost? Currently I'm running a 01 Camaro timing table in an 01 GMC truck with my turboed 4.8 (pr Wait4Me), but I have had to pull a lot of timing to keep knock down with the turbo especially at highway cruising speeds and higher Grams/Cylinder (2-5 lbs of boost while cruising). I was thinking of going back to a stock timing table and use A0010 to pull timing based on boost, since I can make boost in all sorts of funny places with this small motor and the turbo. This would let me run more sane amounts of timing in some areas when not boosting. Any thoughts on this?
