Results 1 to 10 of 19
Thread: Can someone help me out with calc.pids
    Oct 2010
    Default Can someone help me out with calc.pids
    I went through my calc_pids text and to me it looks messed up I tried to piece together what all you guys are using and think I got alot that aren't needed and mixed up some that are. My LTFT ones are golden I just need the AFR ones. Basically to log AFR, EQ, AFR BEN correction, EQ BEN correction. OR if you can clean mine up i'd appreciate it.
    Nov 2006
    Default My 2¢
    The formula for CALC.BENS1 should be "({GM.EQIVRATIO}/{EXT.WO2EQR1})"
    and the units changed to factor.
    I don't know what "({GM.EQIVRATIO}*{EXT.WO2LAM1})" will give you.
    The commanded AFR PID (from EQ) should be "(the value of {B3601}/{GM.EQIVRATIO})"
    Multiple sets based on different AFR values may cause some confusion.
    If you change {B3601} then simply paste the value into the PID expression.
    I have found {GM.AFR} to be out of sync with {GM.EQIVRATIO}, so don't waste a channel on it.
    LC-1 WBO2
    You already know that that is the same as "({GM.EQIVRATIO}/{EXT.WO2EQR1})", right...?
    lam = 1/eqr
    Nov 2006
    lam = 1/eqr
    I see, another form of BEN.
    This would the option for analog instead of making a commanded Lambda PID from EQ.
    LC-1 WBO2
    Oct 2010
    Yeah I really don't plan on using analog WB anyways, If I do i'll come to that road later. I just want to make sure when I get a BEN factor that it's right and i'm using the right ones. All the pids I require show up as supported but i'm not 100% sure the formulas are correct.
    Default Calc_pids.txt file for 4.3L engine displacement
    Are you obtaining the AFR/LAM/EQR from the LC-1 using serial comms...?
    [ ok, I see we can we eliminate the analog LC-1 pids ]
    Your engine displacement is 4.3L...?
    See attached cleaned up file.
    Edit: I decided I didn't like AFR in CLC-00-110 so I deleted the AFR portion of CLC-00-110 [it refused to work right] (see attached).
    Edit: I decided to simplify CLC-00-110 so I deleted the EQR portion of CLC-00-110 [it ok, but it was complicated] (see attached).
    Note: the attached calc pid file include's pavetim's diesel mpg pid (won't work on gas PCM's).
    Oct 2010
    Honestly Joe I don't know much about EQ and lambda. Until I learn better I use afr cause I know afr.
    Quote Originally Posted by pavetim View Post
    They are related as follows:
    For commanded air/fuel:
    AFR = stoichAFR * Lambda = stoichAFR / EQR
    For wideband air/fuel:
    i.e. AFR is always proportial to Lambda (i.e. multiplied by the stoichAFR) and inversely proportional to EQR.
    i.e. note that Lambda = 1/EQR.
    Oct 2010
    Nevermind I missed it lol
    Commanded EQR is handy because it quickly tells you how rich/lean is being commanded regardless of fuel used (e.g. EQR 1.2 is 20% rich for any fuel).
    Wideband Lambda is handy because is quickly tells you how much to multiply VE or MAF by to correct it (e.g. Lambda 0.83 means multiply by 0.83 regardless of fuel).
  1. Some pids not available on default vs my pids
    By LS1Nova in forum General
    Last Post: July 19th, 2010, 09:45 AM
  2. Calc Pids
    By minytrker in forum External A/D inputs
    Last Post: February 19th, 2010, 04:39 AM
  3. Missing calc.pids
    By VetPet in forum General
    Last Post: December 4th, 2005, 03:01 PM
  4. CALC pids
    By purrvert in forum General
    Last Post: October 24th, 2005, 11:32 PM
  5. Idle Tuning with new pids (calc pid file included
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2005, 01:06 PM
