Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Can someone help me out with calc.pids
  1. #11
    Oct 2010
    Nevermind I missed it lol
  2. #12
    Nov 2006
    You already know that that is the same as "({GM.EQIVRATIO}/{EXT.WO2EQR1})", right...?
    lam = 1/eqr
    I see, another form of BEN.
    This would the option for analog instead of making a commanded Lambda PID from EQ.
    LC-1 WBO2
  3. #13
    See my edits to post #4.
  4. #14
    For those with 5.7L displacement see attached.
  5. #15
    Oct 2010
    Ok starting to make sense about EQ and lambda. So if I used my wideband to tune for CL and PE what would be the best way to do it. Would it be better to use a BEN using AFR vs commanded or is there a better/easier way to modify the VE, MAF freq table using a WB?
    Ok without looking at my calc_pids.txt if I wanted to use EQ to fix the VE table is this the right rationale? correction factor= EQ/commanded AFR and just take that number and paste-multiply into the VE table?
  6. #16
    Jul 2008
    Tim you really have me and probably a lot of other readers pretty confused. I thought we already did CALC.VE Table which modifies your MAF and VE Table. Its the same technique for PE Mode/WOT. You don't need to alter your VE Table..its being done by the calculations.
    It still sounds like you are confusing AUTOVE and CALC.VE Table or you are convinced that somehow you have to separately alter the VE Table.
    Perhaps Joecar can straighten you out. I think you are asking the same questions over and over and IMO really making it harder than it needs to be. Whats hanging you up?
  7. #17
    Oct 2010
    I understand now how to tune using the NB for CL and then the WB during PE. But after looking at my calc_pids.txt I just want to make sure i'm actually using the correct formulas for the VE/MAF corrections. I know how to use the NB for the VE table i'm good on that, I'm just makin sure I have the correct formulas so when I do the correction using a WB it dont mess it up. I might have to think a different way because I like to look at AFR, it's easier to me. But need to make sure i'm doing the corrections the right way using I guess EQ is the best? Cause from what i've read using AFR to make your VE/MAF corrections isn't good? Cause like I said before I tried to piece together calc.pids and think I jacked it all up, but Joecar fixed my pids for me, just need to understand how to use them.
  8. #18
    Yes, the formulas look correct if your engine size is 4.3L.
    To look at commanded AFR do this: log GM.EQIVRATIO (instead of GM.AFR) and use the CALC.AFR pid to view it as an AFR
    (first edit CLC-00-001 to be the stoichiometric AFR of the fuel you're using, e.g. 14.63 for gas, 14.12 for E10, 9.78 for E85, etc...).
    The CALC.WO2BEN1 pid uses GM.EQIVRATIO and EXT.WO2LAM1.
    When using LTFT's for correction, use CALC.LTFTBEN.
    Avoid using CALC.STFTBEN, CALC.STFT, CALC.LTFT for anything other than viewing.
    CALC.EQR is used for viewing EQR from logged GM.AFR (which you shouldn't be logging), so it is never needed.
  9. #19
    Oct 2010
    Wow that makes perfect sense now, thanks Joe and Shawn think I got it now, but also got the inside working from your explainations too. Thanks.
  1. Some pids not available on default vs my pids
    By LS1Nova in forum General
    Last Post: July 19th, 2010, 10:45 AM
  2. Calc Pids
    By minytrker in forum External A/D inputs
    Last Post: February 19th, 2010, 05:39 AM
  3. Missing calc.pids
    By VetPet in forum General
    Last Post: December 4th, 2005, 04:01 PM
  4. CALC pids
    By purrvert in forum General
    Last Post: October 25th, 2005, 12:32 AM
  5. Idle Tuning with new pids (calc pid file included
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2005, 02:06 PM
