Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 82
Thread: January 24th 2011 pre-release
  1. #21
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Quote Originally Posted by Tordne View Post
    LML is still only supported for scanning. We are also aware that some PIDs may have changed in the LML and may either be reported as invalid, or log incorrect data. Currently we don't have LML PID data available so are not able to determine the differences.
    I cant find any LML scanning in either the V7 scan tool or V8?
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
  2. #22
    Oct 2004
    Me either actually. I just emailed Paul as I understood that LML scanning had been re-enabled in is latest build.
    Andrew
    EFILive Crew
  3. #23
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Where is the firmware update? I must have missed something...thanks!
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
  4. #24
    Apr 2008
    It mentions if you have the current firmware out of the public release then you are up to date. So check to see you are running 2.07.04
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
  5. #25
    Nov 2009
    yes that is the firmware i am running, only difference is mine didnt have the jan-23rd date..it has the nov 30th date. That is why i was concerned. but guess im good to go.
    -Kory
  6. #26
    Oct 2004
    Quote Originally Posted by DURAtotheMAX View Post
    Actually, in V7 just select LBZ or LMM and it will work.
    Andrew
    EFILive Crew
  7. #27
    Jul 2007
    Simon, I said one day this would come back and bite you.
    You are running what is now a defunct custom OS, this is the one with the valet mode etc? As I mentioned, it is totally unsupported, it's too hard (actually, really, really hard) to keep supporting what is essentially a beta custom OS that was never really released.
    Yes, I know.... I just really like that valet mode. It's not a huge issue and I'm half way through redoing the tune with a stock OS anyway, but the switchable tunes is nice. I used them on holidays so I could quickly switch to a 95RON - towing tune once the 98RON fuel ran out and back again as we hit the bigger towns. But I know there is other pressing work to be done so if push comes to shove, I'll just have to keep and old version in file.
    Simon.
  8. #28
    Dec 2005
    V8 scanning works for BBL. Still a few small bugs. I just need to get all the data to Paul.
    2011 LML 3500HD CC D/A 4x4
    2006 LBZ 3500 CC D/A 4x4 Sold
    2001 LB7 2500HD D/A 4x4 Sold
  9. #29
    Aug 2010
    Unenlightened question from the Gen III guy. Hope to transition into Gen IV conversions by no later than year’s end - still working out some R&D type information.
    When you state “full flash” of the E38 / T42 / T43 - does that mean the same thing as “full flash” does with respect to the LS1-B PCM ?
    That is, does the potential now exist for EFILive to full flash a 2007 V6 Impala E38 with a 2007 V8 truck E38 tune and have it fully functional ?
    Or does a “base tune” still need to be flashed in first with a Tech 2 / Mongoose type device ?
    Taz
  10. #30
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    Quote Originally Posted by Dmaxink View Post
    You need to update your firmware to the Jan-23rd date. I think I saw that you have to use EFILive Explorer and do it manually.
  1. January 2011 update
    By GMPX in forum Cummins 5.9L
    Last Post: January 15th, 2011, 07:28 PM
  2. Pre release 7.5.1
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2007, 08:55 PM
  3. V7.2.1 pre-release is publicly available
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: May 8th, 2005, 02:29 PM
  4. V7.1.9 Pre-release is now available
    Last Post: April 13th, 2005, 02:47 PM
