Results 1 to 5 of 5
Thread: LB7 injector balance rates
    Default LB7 injector balance rates
    I finally ran the injector balance test with efi, here are my averages after idling for awhile at temperture. How do they look? (2003 LB7 stock tune)
    1. -1.65mm³
    2. -3.49mm³
    3. -.30mm³
    4. -1.17mm³
    5. .29mm³
    6. 2.71mm³
    7. 2.84mm³
    8. .97mm³
    Lorenz, you need to specify units.
    1. Start and run the engine until the engine coolant temperature is more than 82°C (180°F).
    2. Turn OFF all accessories.
    3. Hold the brake pedal in the fully applied position. A hiss will be noticeable when the brake is fully applied.
    4. Place the transmission in Drive.
    5. Idle the engine for more than 30 seconds.
    6. Record the Balancing Rate Cyl.1-8 parameters from the scan tool while the engine is at idle speed.
    7. Repeat steps 2-6 with the transmission in Neutral.
    -6 mm³ and +6 mm³ is OK in gear, and -4 mm³ and +4 mm³ is OK in neutral.
    Thanks I added them, it was mm³. I did that in park. I will re-do it Wed and follow your instructions and post my results. Thanks for the help.
    Aug 2014
    Quote Originally Posted by minytrker View Post
    1. -1.65mm³
    2. -3.49mm³
    3. -.30mm³
    4. -1.17mm³
    5. .29mm³
    6. 2.71mm³
    7. 2.84mm³
    8. .97mm³
    I'm brand new to EFI live. How do you set up to do the balance rates. I've looked at the tutorials and haven't found any instructions. Can you help or point me in the right direction? Thanx
    Mar 2009
    Also you need to log your fuel rate when checking them to get accurate numbers. If you have multiple injectors going out, it will lower your fuel rate at idle and keep the balance rates looking good.
  1. injector flow rates
    By GMMAD in forum Gen III V8 Specific
    Last Post: January 21st, 2011, 07:53 PM
  2. LB7 Fuel Injector balance rates reading 0
    By StuntHeavy in forum Duramax LB7
    Last Post: July 7th, 2010, 02:03 PM
  3. injector flow rates
    By 02sierra4x4 in forum Gen III V8 Specific
    Last Post: September 30th, 2009, 07:05 PM
  4. Cant read balance rates on an 01
    By Dmax15 in forum Duramax LB7
    Last Post: August 14th, 2009, 04:28 PM
  5. Balance rates
    By diesel freak 123 in forum Duramax LB7
    Last Post: April 22nd, 2008, 02:55 PM
