Originally Posted by
WeathermanShawn
Simon and others:
In all honesty it is a little over my head..But your last comment makes sense. I can display it as a 0.0 or 1.0.
What am I trying to do is say if PE Mode =0, then use CLC-00-003..
If PE Mode =1.0 then use CLC-00-004..
*CLC-00-003
% 0.0 100.0 .2 "iff( {CALC.PEMODE},0)"{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA. C}+273.15)*3445.2/(5.669*{SAE.RPM}*{SAE.MAP.kPa})*{CALC.LTFTBEN}"
VE 0.0 3.0 .4 "iff( {CALC.PEMODE},0)"{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA. C}+273.15)*15/({SAE.RPM}*{SAE.MAP.kPa})*{CALC.LTFTBEN}"
*CLC-00-004
% 0.0 100.0 .2 "iff( CALC.PEMODE},1)"{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C }+273.15)*3445.2/(5.669*{SAE.RPM}*{SAE.MAP.kPa})*{CALC.BEN1}"
VE 0.0 3.0 .4 "iff( CALC.PEMODE},1)"{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C }+273.15)*15/({SAE.RPM}*{SAE.MAP.kPa})*{CALC.BEN1}"[/B]
I'm 'choking on the 'iff' expression. When an user is in PE Mode I want them to use the WO2BEN Pid, when they are not in PE Mode then calculate the PID using LTFTBEN.
By the way, nice vid on that brake!!!
