It's back, COS 3 04073003. After making a global change to 14.63 on table B3604 it still won't start. B0106 now has the correct value of 8 (I did play with this a bit but it didn't give me any results) My thought was the sooner it referenced the command AFR it should have started, it didn't. So I'm going to move to B0102 VE while cranking and see if that gets me running.
FWIW I'm not using the latest Cal files. But have made the changes called out in the Repost thread.
