Hello,
Currently I am running N/A on my 99 T/A. Engine is a stock bottom end with P&P 243's, LS6 intake, TR224-112, stock MAF, BBK 80mm tb, A4 with 3400 2.1 stall. Previous to the S/C, I was running a 125 wet shot but that's gone now.
As mentioned before, my tune for N/A is solid but I need to establish a safe base tune to begin using my P1SC Procharger. I have added 60# Motron's and the S/C uses the standard twin Procharger intercoolers.
I plan to run 6-7# of boost.
I have attached my N/A tune and a log file for reference. I expect that I need to pull timing and drop WOT AFR to~11:1.
I just need a little advice so I don't scatter on my maiden voyage.
Thank you in advance for any help.
