I got the car back together and put in the SDCL 2Bar tune. It started fine (a bit rough) at first. Two things that were immediately obvious. First, my AFR was about 15-16:1 when cold. B3647 is set around 14.5:1 and A0008 multiplier is at 1.25 at low ECT. Not sure why is was so lean. Second the idle was around 1050rpm and the car stalls when I give it throttle. Once I get it coaxed up to 1800rpm or so, I can throttle it fine. It is just a stall off-idle.
I attached my tune and a log of the car running in park.
Thank you
