Results 1 to 8 of 8
Thread: Torque control parameter
    Nov 2003
    Default Torque control parameter
    In the engine calibration section there is a section about engine torque.
    Ane parameter is maximum engine torque. Is this parameter used in
    calculations during engine operation or is it a limit that when exceeded
    spark timing will be retarded?
    Thanks,
    Gert
    Nov 2003
    Nobody has the foggiest idea how this parameter is used _ I imagine
    it is there for a reason,
    Gert
    Lifetime Member jfpilla's Avatar
    Default Re: Torque control parameter
    Quote Originally Posted by 2000ssnb
    Thanks,
    Gert
    I can't open the sections since I don't have Flashcan yet, but I believe you are referring to torque management. Your right that timing is pulled when you exceed that parameter. There is a belief that 639 is the maximum value that can be put in or the computer will not handle the instruction correctly.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Lifetime Member 87gmc's Avatar
    Apr 2004
    I would like to find out also it seems when im wot and my trans shifts from 1-2 its like not a solid shift almost like you shift manually from 1-2 wot and let off of the clutch slowly. I noticed when logging my timing is going from like 12 to -3 when it does shift durning the hesitation then climbs back up.
    Is there a parameter that controls timing when shifting or does all this have to do with torque management. I would like a firm shift with no lagging. :?:
    Nov 2003
    The max allowed torque is specified in the parameter
    section under
    - engine calibration
    - engine torque
    Parameters Max allowed engine torque 350
    for any of the stock .tun files of Camaros or vettes.
    This seems low to me so I was wondering if there is an
    "unwanted" limit.
    Gert
    Nobody has the foggiest idea how this parameter is used _ I imagine it is there for a reason,
    Gert
    It is used by the traction control system (when active).
    It affects the PWM output to the EBCM (Electronic Brake Control Module).
    The code in the PCM is pretty damn good, there is sane limiters for every value entered, if you entered 1000ft-lb, the PCM will cap it at the maximum that calcuation can work out to anyway which is about 640ft-lb.
    As for the trans soggy upshift problem.......checkout the new spark PID "GM.EST_XMSN_DMA" in the latest update you guys will get VERY soon. This shows the timing being pulled by the Transmission torque managment routine, we used to just have a Torque management PID, but there is too many factors involved in that, so we expanded on it a little.
    In the meantime, checkout tables - D0801 - D0803. Reduce these by 50% and see how it feels.
    Quote Originally Posted by GMPX
    Gert
    You might also try reducing Desired shift times. This will reduce the time it takes to complete a shift. Suggest you try one idea at a time.
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Quote Originally Posted by jfpilla
    These are used for the Trans Learn adjustments, you are right, you need to change these too for a quicker desired shift time or the PCM will adjust pressures in an attempt to get those shift times.
  1. Scan parameter warning
    By Chriskaw7r in forum Gen III V8 Specific
    Last Post: March 18th, 2010, 06:40 PM
  2. 99 to 02 conversion parameter
    By DaddySS in forum Gen III V8 Specific
    Last Post: September 2nd, 2007, 10:59 AM
  3. Idle Parameter questions!
    By Redline Motorsports in forum Gen IV V8 Specific
    Last Post: November 24th, 2006, 01:24 AM
  4. Torque management, TCS, TCS fast torque loss
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2006, 05:16 AM
