Results 1 to 5 of 5
Thread: Can someone verify this layout of the 4x cam trigger wheel?
    Member tunedportcj5's Avatar
    Sep 2006
    Default Can someone verify this layout of the 4x cam trigger wheel?
    Here is a quick sketch of a 4x trigger. Can someone verify that the angles are correct for each of the "teeth"?
    I dont have a 4x wheel on hand to verify an I'd hate to disassemble the front of my LY6 to verify
    Thanks!
    David
    '94 Lexus SC300 LY2 4.8, LS6 cam/springs, E38, LS3 MAF, LS2 intake, 88mm TB, 2bar MAP, T42/4L80e, mpt70
    www.terratraction.com/gallery
    Aug 2010
    Probably best to purchase a 4x cam sprocket, and verify first hand that your CAD type depiction is accurate.
    GM part # 12586481 is a 4x Gen III / Gen IV cam sprocket (3 bolt design). Price ranges from $18 to $30 depending on the source - small price to pay for accuracy.
    Regards,
    Taz
    Sep 2006
    Good idea.. thanks for the part#
    Dec 2007
    Your diag looks fine. The reluctor shapes as you can see are pretty right and follow the radial line from the centre.
Name:	58X Cam Gear.JPG
    Feb 2011
    tunedportcj5,
    I saved and printed your sketch and noticed that there are 'flats' on each segment of the wheel. Are there supposed to be 'flats' or is it supposed to be a smooth curve?
    Also, how did you come up with the difference between the major and minor diameters?
    I'm asking out of ignorance.
    Thanks,
    JP
  1. Cam Wheel Problem
    By Picto in forum Gen III V8 Specific
    Last Post: August 16th, 2010, 12:07 AM
  2. Just want to verify what I belive (upgrading OS)
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: June 15th, 2008, 09:17 AM
  3. Please verify...
    Last Post: September 13th, 2006, 09:29 AM
  4. Calculated VSS (used to verify speedo calibration)
    By joecar in forum Tips and tricks
    Last Post: January 19th, 2006, 04:18 PM
  5. Wheel sensors
    By Dark Angel in forum Tips and tricks
    Last Post: October 7th, 2005, 08:54 AM
