Hey Guys,
Today I was trying to read the ECM and the computer would not communicate with the V2 no matter what I did. The truck is 100 percent stock with no remote starter or absolutely any modifications to it. I tried disconnecting the battery and rebooting the ecm that way, to no avail however.
I am running Build 133 currently (didnt want to update after hearing the LLY issues)
Boot Block 2.06.03
Firmware 2.06.41
Here is a copy paste from the command window
20:06:00.049: Scanning for EFILive FlashScan V2 USB
20:06:00.068: Autodetect interface ...
20:06:01.798: Interface not detected
20:06:02.406: Scanning for EFILive FlashScan V2 HAPI
20:06:02.425: Autodetect interface ...
20:06:02.598: Interface firmware version: 2.6.41
20:06:02.608: Connection to [FSV2] interface is OK
20:06:02.636: Interface firmware model: FSV2
20:06:02.658: Interface firmware version: 2.6.41
20:06:02.680: Interface firmware date: Sep 12, 2010
20:06:02.700: FlashScan serial number: 003719905779
20:06:02.724: FlashScan license number: 003719905779
20:06:02.753: Disconnecting ...
20:06:03.507: CAN-VPW Bridge Deactivated
20:06:03.517: Disconnected
20:06:04.131: Scanning for EFILive FlashScan V2 USB
20:06:04.150: Autodetect interface ...
20:06:05.881: Interface not detected
20:06:06.486: Scanning for EFILive FlashScan V2 HAPI
20:06:06.501: Autodetect interface ...
20:06:06.682: Interface firmware version: 2.6.41
20:06:06.687: Connection to [FSV2] interface is OK
20:06:06.707: CAN-VPW Bridge Activated
20:06:06.782: Current protocol set to: "ISO 15765 CAN"
20:06:06.792: Autodetect PCM...
20:06:08.812: PCM not detected.
20:06:08.822: Autodetect ECM...
20:06:08.847: Connection to ECM is OK
20:06:08.857: Autodetect TCM...
20:06:08.887: Connection to TCM is OK
20:06:08.907: Current protocol: "ISO 15765 CAN"
20:06:08.937: Interface firmware model: FSV2
20:06:08.957: Interface firmware version: 2.6.41
20:06:08.977: Interface firmware date: Sep 12, 2010
20:06:08.997: FlashScan serial number: 003719905779
20:06:09.017: FlashScan license number: 003719905779
20:06:09.082: Getting status...
20:06:09.122: Status: OK.
20:06:09.917: Bootloader version: E38a_v1.2R (06D6-325C)
20:06:09.922: Preparing ECM for reading flash...
20:06:09.952: ECM seed is: $6089
20:06:09.962: Unlock attempt 1 of 4
20:06:10.307: Unlock attempt 2 of 4
20:06:10.667: Not ready, waiting 1 second for retry...
20:06:11.900: Not ready, waiting 1 second for retry...
20:06:13.135: Not ready, waiting 1 second for retry...
20:06:14.365: Not ready, waiting 1 second for retry...
20:06:15.595: Not ready, waiting 1 second for retry...
20:06:16.824: Not ready, waiting 1 second for retry...
20:06:18.054: Not ready, waiting 1 second for retry...
20:06:19.284: Not ready, waiting 1 second for retry...
20:06:20.519: Unlock attempt 3 of 4
20:06:20.869: Not ready, waiting 1 second for retry...
20:06:22.106: Not ready, waiting 1 second for retry...
20:06:23.337: Not ready, waiting 1 second for retry...
20:06:24.571: Not ready, waiting 1 second for retry...
20:06:25.808: Not ready, waiting 1 second for retry...
20:06:27.048: Not ready, waiting 1 second for retry...
20:06:28.278: Not ready, waiting 1 second for retry...
20:06:29.508: Not ready, waiting 1 second for retry...
20:06:30.739: Unlock attempt 4 of 4
20:06:31.102: Not ready, waiting 1 second for retry...
20:06:32.330: Not ready, waiting 1 second for retry...
20:06:33.560: Not ready, waiting 1 second for retry...
20:06:34.800: Not ready, waiting 1 second for retry...
20:06:36.030: Not ready, waiting 1 second for retry...
20:06:37.265: Not ready, waiting 1 second for retry...
20:06:38.500: Not ready, waiting 1 second for retry...
20:06:39.737: Not ready, waiting 1 second for retry...
20:06:40.969: Initializing ECM...
20:06:42.217: Initializing ECM, step 1 of 4
20:06:42.225: Initializing ECM, step 2 of 4
20:06:43.463: Initializing ECM, step 3 of 4
20:06:45.913: Initializing ECM, step 4 of 4
20:06:46.183: Disconnecting ...
20:06:46.940: CAN-VPW Bridge Deactivated
20:06:46.950: Disconnected
20:07:07.050: Done!
It then give me an error that the bootloader was rejected and some possible reasons (RPM, VSS are not 0, or a memory fault was detected.
I was just curious as to what needs to be done to be able to read this ecm (if possible).
Thanks for your time,
Mitch
