Results 1 to 2 of 2
Thread: EfiLiveV4 Evaluation: problem loading definition *xml
    Jan 2011
    Default EfiLiveV4 Evaluation: problem loading definition *xml
    Sorry to impose, but it appears I can't load any of the existing vehicle definition files. Once I have clicked the menu icon "select vehicle and load definition file from XML"... then select a xml file (ie gmh-vt8-ls1.xml), the following message appears:
    27:48.296: Opening COM1 8228,8,N,1
    27:48.296: Can't open Com1. The system cannot find the file specified.
    Can any one point me to a forum thread or help me out? Cheers
    Lifetime Member limited cv8r's Avatar
    May 2005
    If you read the efilive thread "new to tuning" it may help you. A bit long winded, but there is some discussion in there on setting up com ports.
    It's all good until it goes "Bang"
  1. Odd problem with loading a tune
    By Telco in forum Gen IV V8 Specific
    Last Post: November 27th, 2013, 10:24 AM
  2. 1986 Transam EFILiveV4 connection
    By gm-services in forum EFILive V4
    Last Post: May 18th, 2011, 01:02 PM
  3. Need definition for 16197427
    By serial_killer in forum EFILive V4
    Last Post: October 7th, 2009, 08:59 AM
  4. problem loading new os 411 swap
    By haulinit in forum FlashScan V1
    Last Post: April 20th, 2009, 09:33 AM
  5. Evaluation Key Not Working?
    By CGTMS in forum EFILive V4
    Last Post: January 3rd, 2008, 03:39 PM
