Results 1 to 5 of 5
Thread: How to scan/check injector balance rates?
    Junior Member duramax07tmd's Avatar
    Feb 2010
    Default How to scan/check injector balance rates?
    I am still new to EFI so please bear with me. I have an 07 LBZ duramax with the DSP5 and I was wondering how I go about checking the injector balance rates with the V2? Do you just use the V2 or the V2 with it hooked up to the lap top? Does it matter what setting on the DSP5 I need to leave it on to check it, or do I use the stock setting?
    Is there a chart or any info that tells you what the injector rates are suppose to be for each motor? I.E. (LB7, LLY, LBZ, LMM)
    Thank you and any help is much appreciated!
    07 Chevrolet LBZ
    CCSB 4x4
    EFI Live DSP5 Duramaxtuner.com
    PPE & Aeroforce Gauges
    5" MBRP & DE Direct Pipe
    EGR Blocked & PCV Reroute
    PPE Ported Fuel Fittings
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Feb 2010
    I just noticed that I posted this in the general section when i intended to post in the diesel section. Please move this if need be.
    Thanks!
    07 Chevrolet LBZ
    CCSB 4x4
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Feb 2010
    Thank you Nick! Greatly appreciate it!
    07 Chevrolet LBZ
    CCSB 4x4
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Quote Originally Posted by duramax07tmd View Post
    Thanks!
    No worries, I moved it to here (LLY, LBZ, LMM), is this good here...?
  1. LB7 injector balance rates
    By minytrker in forum Duramax LB7
    Last Post: August 24th, 2014, 02:51 PM
  2. LB7 Fuel Injector balance rates reading 0
    By StuntHeavy in forum Duramax LB7
    Last Post: July 7th, 2010, 02:03 PM
  3. injector flow rates
    By 02sierra4x4 in forum Gen III V8 Specific
    Last Post: September 30th, 2009, 07:05 PM
  4. Cant read balance rates on an 01
    By Dmax15 in forum Duramax LB7
    Last Post: August 14th, 2009, 04:28 PM
  5. Balance rates
    By diesel freak 123 in forum Duramax LB7
    Last Post: April 22nd, 2008, 02:55 PM
