Thread: '09 LMM DPF sensors and tubes?
    Dec 2006
    Default '09 LMM DPF sensors and tubes?
    What is the best thing to do with the 4 (two pairs) of things that run into the DPF? On an unknown brand of DPF delete pipe, there are two ports, I am assuming to put back in the two tubes that are for EGT? I am 99% sure the only things that come out of the filter are a pair of pressure difference sensors and a pair of EGT probes (?). Should I tie off all 4 (but then the ports on the pipe?) or plug the two tubes back in like I've seen on another truck. Will this give any kind of useable EGT reading to the scan tool or does a calculation have to be made for accuracy. Thanks!
    8.7 @ 84 (1/8 mile) bolt-ons
    Nov 2009
    We generally just tie them up and if the pipe comes with bungs weld them up. There would need to be some sort of correction factor if one was wanting to use the factory sensors as egt monitoring, and i wouldn't be confident in getting my reading right there...i like mine in the manifold.
    just my .02
    -Kory
    http://www.PPEI.com/
    Dec 2006
    Thanks for the info! Why did the dumb delete pipe come with ports if that is not an ideal place to put them? Has anyone just disconnected the sensors and left them in the bungs to plug the holes in the delete pipe like I'm planning? So the tubes wouldn't really leak of divert any exhaust if they were plumbed back in.
    Nov 2009
    most of the time you can order them with/without bungs, but yeah thats no problem...you can do that too
    -Kory
    Dec 2006
    thanks again
    Nov 2009
    no prob buddy, glad i could help out!
    -Kory
  1. Setting rear O2 sensors to act as bank 1 (primary) O2 sensors
    By T34418L31 in forum Gen III V8 Specific
    Last Post: November 6th, 2010, 03:59 PM
  2. LMM-MAF and Regen/DPF relationship
    Last Post: September 22nd, 2010, 01:29 PM
  3. 7.5 LMM DPF delete and EFI V2
    By clickjocky in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 5th, 2008, 03:36 PM
  4. LMM O2 sensors?
    By Riccas in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 9th, 2007, 04:28 PM
