Results 1 to 8 of 8
Thread: Dpf delete
    Jul 2009
    Default Dpf delete
    I recently deleted a dpf on a customers truck, as well as set several code's to:
    non emmisions mil off, and still have the light on, these are the reoccuring codes P0401, P2033, P2455, P0546.
    i know P0401 is the EGR, the really isnt the problem i can fix that one.
    the truck was run for about 10 hours before the others set, its a 8594 truck.
    im using v7.5.6 build 139
    input would be greatly appreciated.
    Last edited by relentless addiction; February 8th, 2011 at 05:47 AM. Reason: spelling
    Lifetime Member bobo's Avatar
    Nov 2005
    You messed up the tune and the codes are setting.
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Set the codes to "not reported, no MIL" Instead of non-emissions, no MIL... Hope this helps more than telling you that you simply "messed up".
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Jul 2009
    Quote Originally Posted by LBZoom View Post
    ok thanks, for some reason i thought i tried that and they still set... ill try again thanks for the quick reply
    Jun 2008
    Hey Relentless addiction. any luck with the issue at hand?
    Jan 2007
    I have same problem with a 2009, operating system 12628594
    dpf was removed, also the egt 1 and 2 were removed and the differential pressure sensor removed.
    i have triple checked, codes p2455, p0546 and p2033 are all set to X: NOT REPORTED,NO MIL
    codes are still setting, so whats up with that?
    Feb 2011
    I also have an 2009 with the 12628594 operating system that is setting off those same codes, I tried to plug back in my egts and the differential pressure sensor (since im using a stock hollwed out dpf) and it keeps setting the code P2453 wich is a code for the differential pressure sensor even though I have it set to X:NOT REPORTED,NO MIL.
    I set B2501 to no and B2502 to 0 and switched all dpf related dtc's to X:NOT REPORTED,NO MIL. and my truck still went into regen mode. Im completly out of ideas on what might fix this problem so any help would be greatly appreciated.
    Jan 2007
    I have to clerify, the codes were setting as pending, mil not coming on but codes set.
    i contacted support and they said it is to do with how the bosch controller handles codes, they can make a change to the file that we cant with the public editor.
    Are you sure your truck went into regen? how do you know it regened?
    with b2501 and b2502 set the way you have them it should not regen.
  1. DPF and EGR Delete
    By pONSi in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 13th, 2010, 09:48 AM
  2. DPF software delete
    By Dream2000 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 7th, 2010, 02:51 AM
  3. dpf delete help
    By escalante127 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 6th, 2010, 07:27 PM
  4. Dpf delete
    By LIL DAVE in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 9th, 2009, 06:24 AM
  5. dpf delete = codes?
    By zackbennett in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 21st, 2009, 05:39 AM
