Has anyone done this to their L76? I'm trying to find a good detailed write up on whats involved so I can finally put a cam in my truck...
FLASHSCAN V2 & AUTOCAL
Not sure about VVE cause my L76 doesn't have any cam phasers. if you want to disable DOD (AFM) completely it is a single table change from Yes -> No.
Andrew
EFILive Crew
I meant mechanically,(disabled DOD, with EFI Live when I had 3,500 miles on my truck) I don't want to use an aftermarket DOD/VVT cam, want to go BIG LS2 or LS7 non-DOD non-VVT cam...
Gotcha!
I disabled DOD about two days after picking up the vehicle from the dealer. Probably had 150kms on it
Other than the lifters I'm not sure what else might might need to be changed. I suspect if you doing a cam project the lifters, pushrods, springs etc are all going to get the treatment anyway...
Andrew
EFILive Crew
Here is the parts needed to delete DOD.
Head Bolts
Head Gaskets
Hardened Pushrods
LS7 Lifters
LS2 Lifter guide kit
LS2 Valley Cover
Valve Cover Breather Block-Off
LS7 Camshaft Sprocket
Timing Chain Dampner
PCV Hose for Non-DOD applications
Exhaust Gaskets
Timing Chain Bolts
Thanks for posting up list Lorenz...
You will also need the LS2 timing cover and three camshaft sprocket bolts. Get the cam with the three bolts, not the large single bolt.
Al
