Results 11 to 20 of 22
Thread: EFI re-flash problems...
  1. #11
    Apr 2010
    Any advice here guys ive tried everything....
  2. #12
    Junior Member cook's Avatar
    Jan 2008
    Hi, when you disable the lift pump are you doing that in the fuse box.
    09 K2500 HD DMAX Z71 cc sb efi live Dsp5 tuned by me , banks ram air ,autometer gauges ,airdog 165, transgo jr ,pcv re route ,on 285's with air ride soon to come Gmax 6
  3. #13
    Apr 2010
    Yes i am....i might add that in the past if i was in a hurry with the stock motor i would flash it with the pump running and still had no probs!
  4. #14
    Jan 2008
    Quote Originally Posted by 770johnnyw View Post
    the reason i ask is that if you have a double fuse tap like i do when you pull the pump you need to put a temporary fuse in that spot ,assuming you tapped into one of the ign spots just a thought.
  5. #15
    Apr 2010
    Yes i do have the double fuse tap its an air dog 150. I will try that tomorrow but like i said i usually just pull it to keep the pump from running! You think that fuse would cause it to not read the O.S?
  6. #16
    Apr 2007
    Maybe try downloading the latest software, and then updating the firmware of the V2 unit.
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
  7. #17
    Apr 2010
    ok will do...remind me how i upgrade the v-2???
  8. #18
    Jan 2008
    yes,had a similar problem on customer vehicle ,was throwing low voltage codes and voltage was fine,was plugged into one of the ign spots,let me know how you come out.
  9. #19
    Apr 2010
    ok cool thanks man that may be my problem. As soon as i get off work im gonna give this a shot!
  10. #20
    Apr 2007
    Pretty simple now, just download both the V8 and V7 software from the "Software Updates" section of the forum. The EFILive control panel should pop up for you to update the firmware after you connect it to your PC.
    SOLD - 06 LBZ
    EcoDieselRam Forum
  1. Serious problems with full flash for DSP5
    By gman in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 18th, 2010, 04:37 AM
  2. Flash Scan V2 problems
    By loafycleetus in forum FlashScan V2
    Last Post: April 20th, 2009, 02:51 AM
  3. 2005 colorado I5 flash problems
    By nonnieselman in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: July 9th, 2008, 05:00 PM
  4. Flash problems
    By slowhawk in forum General (Petrol, Gas, Ethanol)
    Last Post: January 10th, 2007, 01:40 AM
  5. Problems with idle after AutoVE flash (again)
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2006, 03:17 PM
