Results 1 to 4 of 4
Thread: Reduced Engine Power while MAFless
    Senior Member mtnman's Avatar
    Sep 2005
    Default Reduced Engine Power while MAFless
    I went through the AutoTune VE tutorial this past weekend and bumped up C6101 by 50% (someone had suggested this step to avoid the "reduced engine power mode), drove the truck for 3 days and everythiing was great. When I drove in this morning and "got on it", the dad gum "reduced engine power" msg flashes and the truck looses power. Dang, I though I had fixed it with the C6101 bump up. Does anybody have any suggestions? Should I bump up C6101 another 50%? I didnt get on the gas back when I went through the tutorial because of the warning that the cats may be damaged if I do that. I'm running the stock OS and personal flashscan version of efilive (no custom OS, 2 bar, 3 bar stuff).
    2003 2500HD,E-Fans, LT headers, Corsa catback, Outlaw intake.
    Sep 2003
    I would increase it more than that for now until you get it dialed in. Its only a table used for tests so it shouldnt hurt anything if you increase it by 100-200%
    Larry - HumpinSS
    Jan 2005
    Rather than just bumping the whole table, try data logging and see where you run into trouble. Chance are, it's at a point in the table that you didn't anticipate. Do you know for certain that the C6101 values are responsible for the Reduced Power condition? If you'd like, I can send you the C6101 table I worked out for my C5. A truck will have higher load values, but you should be able to use it as a guide and adjust as necessary.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Sep 2003
    If you exceed the values in that table DTC 1514 will be set which is Reduced power mode. Its ok to increase the table by 200% for tuning and then when you are done make a map to dial it back in
    The PCM calculates the amount of airflow it expects for a given RPM and throttle position, if these values are exceeded then DTC P1514 will set.
    Larry - HumpinSS
  1. reduced engine power can't be shut off
    By 496chevy in forum Custom Operating Systems
    Last Post: May 31st, 2009, 01:02 PM
  2. P1514 Reduced Engine Power.
    By Mort in forum Gen III V8 Specific
    Last Post: April 2nd, 2009, 12:51 PM
  3. Reduced engine power
    By redlinepd in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 7th, 2007, 08:30 PM
  4. Reduced engine power after autoTune
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2006, 07:08 AM
  5. SD mode = reduced engine power
    Last Post: February 18th, 2006, 12:19 AM
