I have tried on several ocasions to try and read the computer on an 03 lb7 i get the same response everytime. i have had no trouble on my 03 or the other trucks i have programmed. i have tried alt keys and making sure everything else on the truck is unpugged. like i said it reads the tcm fine. this is what it says to me.
08:31:24.312: Scanning for EFILive FlashScan V2 USB
08:31:24.328: Autodetect interface ...
08:31:26.156: Interface not detected
08:31:26.828: Scanning for EFILive FlashScan V2 HAPI
08:31:26.843: Autodetect interface ...
08:31:27.031: Interface firmware version: 2.6.12
08:31:27.031: Connection to [FSV2] interface is OK
08:31:27.062: Interface firmware model: FSV2
08:31:27.078: Interface firmware version: 2.6.12
08:31:27.109: Interface firmware date: Jun 07, 2009
08:31:27.125: FlashScan serial number: 003798697541
08:31:27.140: FlashScan license number: 003798697541
08:31:27.171: Disconnecting ...
08:31:27.562: CAN-VPW Bridge Deactivated
08:31:27.562: Disconnected
08:31:28.250: Scanning for EFILive FlashScan V2 USB
08:31:28.265: Autodetect interface ...
08:31:30.093: Interface not detected
08:31:30.765: Scanning for EFILive FlashScan V2 HAPI
08:31:30.781: Autodetect interface ...
08:31:30.968: Interface firmware version: 2.6.12
08:31:30.968: Connection to [FSV2] interface is OK
08:31:30.984: CAN-VPW Bridge Activated
08:31:31.015: Current protocol set to: "SAE J1850 VPW"
08:31:31.015: Autodetect PCM...
08:31:31.046: Connection to PCM is OK
08:31:31.062: Autodetect TCM...
08:31:31.093: Connection to TCM is OK
08:31:31.109: Current protocol: "SAE J1850 VPW"
08:31:31.140: Interface firmware model: FSV2
08:31:31.171: Interface firmware version: 2.6.12
08:31:31.187: Interface firmware date: Jun 07, 2009
08:31:31.203: FlashScan serial number: 003798697541
08:31:31.218: FlashScan license number: 003798697541
08:31:31.343: Getting status...
08:31:31.406: Status: OK.
08:31:32.218: Bootloader version: DLB7_v1.3R (0496-61DA)
08:31:32.218: Preparing ECM for reading flash...
08:31:32.250: ECM seed is: $EFFD
08:31:32.250: Unlock attempt 1 of 1
08:31:32.656: Disconnecting ...
08:31:33.046: CAN-VPW Bridge Deactivated
08:31:33.046: Disconnected
08:31:53.625: Done!
08:32:21.609: Scanning for EFILive FlashScan V2 USB
08:32:21.625: Autodetect interface ...
08:32:23.453: Interface not detected
08:32:24.125: Scanning for EFILive FlashScan V2 HAPI
08:32:24.140: Autodetect interface ...
08:32:24.312: Interface firmware version: 2.6.12
08:32:24.328: Connection to [FSV2] interface is OK
08:32:24.359: Interface firmware model: FSV2
08:32:24.375: Interface firmware version: 2.6.12
08:32:24.390: Interface firmware date: Jun 07, 2009
08:32:24.406: FlashScan serial number: 003798697541
08:32:24.437: FlashScan license number: 003798697541
08:32:24.453: Disconnecting ...
08:32:24.843: CAN-VPW Bridge Deactivated
08:32:24.859: Disconnected
08:32:25.531: Scanning for EFILive FlashScan V2 USB
08:32:25.546: Autodetect interface ...
08:32:27.375: Interface not detected
08:32:28.046: Scanning for EFILive FlashScan V2 HAPI
08:32:28.062: Autodetect interface ...
08:32:28.250: Interface firmware version: 2.6.12
08:32:28.250: Connection to [FSV2] interface is OK
08:32:28.265: CAN-VPW Bridge Activated
08:32:28.281: Current protocol set to: "SAE J1850 VPW"
08:32:28.296: Autodetect PCM...
08:32:28.328: Connection to PCM is OK
08:32:28.328: Autodetect TCM...
08:32:28.375: Connection to TCM is OK
08:32:28.406: Current protocol: "SAE J1850 VPW"
08:32:28.437: Interface firmware model: FSV2
08:32:28.453: Interface firmware version: 2.6.12
08:32:28.468: Interface firmware date: Jun 07, 2009
08:32:28.484: FlashScan serial number: 003798697541
08:32:28.500: FlashScan license number: 003798697541
08:32:28.609: Getting status...
08:32:28.656: Status: OK.
08:32:29.500: Bootloader version: DLB7_v1.3R (0496-61DA)
08:32:29.500: Preparing ECM for reading flash...
08:32:29.531: ECM seed is: $EFFD
08:32:29.531: Unlock attempt 1 of 4
08:32:29.937: Unlock attempt 2 of 4
08:32:30.343: Not ready, waiting 1 second for retry...
08:32:31.609: Not ready, waiting 1 second for retry...
08:32:32.859: Not ready, waiting 1 second for retry...
08:32:34.140: Not ready, waiting 1 second for retry...
08:32:35.421: Not ready, waiting 1 second for retry...
08:32:36.687: Not ready, waiting 1 second for retry...
08:32:37.968: Not ready, waiting 1 second for retry...
08:32:39.250: Not ready, waiting 1 second for retry...
08:32:40.515: Not ready, waiting 1 second for retry...
08:32:41.796: Unlock attempt 3 of 4
08:32:42.203: Unlock attempt 4 of 4
08:32:42.625: Not ready, waiting 1 second for retry...
08:32:43.890: Not ready, waiting 1 second for retry...
08:32:45.156: Not ready, waiting 1 second for retry...
08:32:46.437: Not ready, waiting 1 second for retry...
08:32:47.703: Not ready, waiting 1 second for retry...
08:32:48.984: Not ready, waiting 1 second for retry...
08:32:50.265: Not ready, waiting 1 second for retry...
08:32:51.531: Not ready, waiting 1 second for retry...
08:32:52.812: Not ready, waiting 1 second for retry...
08:32:54.093: Initializing ECM...
08:32:54.906: Initializing ECM, step 1 of 4
08:32:54.906: Initializing ECM, step 2 of 4
08:32:55.750: Initializing ECM, step 3 of 4
08:32:55.750: Initializing ECM, step 4 of 4
08:32:56.046: ECM lock has been re-armed, attempting to unlock ECM again...
08:32:56.078: ECM seed is: $EFFD
08:32:56.078: Unlock attempt 1 of 4
08:32:56.500: Unlock attempt 2 of 4
08:32:56.921: Not ready, waiting 1 second for retry...
08:32:58.187: Not ready, waiting 1 second for retry...
08:32:59.468: Not ready, waiting 1 second for retry...
08:33:00.750: Not ready, waiting 1 second for retry...
08:33:02.031: Not ready, waiting 1 second for retry...
08:33:03.296: Not ready, waiting 1 second for retry...
08:33:04.578: Not ready, waiting 1 second for retry...
08:33:05.859: Not ready, waiting 1 second for retry...
08:33:07.125: Not ready, waiting 1 second for retry...
08:33:08.437: Unlock attempt 3 of 4
08:33:08.859: Unlock attempt 4 of 4
08:33:09.281: Not ready, waiting 1 second for retry...
08:33:10.562: Not ready, waiting 1 second for retry...
08:33:11.812: Not ready, waiting 1 second for retry...
08:33:13.078: Not ready, waiting 1 second for retry...
08:33:14.328: Not ready, waiting 1 second for retry...
08:33:15.609: Not ready, waiting 1 second for retry...
08:33:16.859: Not ready, waiting 1 second for retry...
08:33:18.140: Not ready, waiting 1 second for retry...
08:33:19.421: Not ready, waiting 1 second for retry...
08:33:20.687: Initializing ECM...
08:33:21.500: Initializing ECM, step 1 of 4
08:33:21.500: Initializing ECM, step 2 of 4
08:33:22.328: Initializing ECM, step 3 of 4
08:33:22.328: Initializing ECM, step 4 of 4
08:33:22.625: ECM lock has been re-armed, attempting to unlock ECM again...
08:33:22.781: Initializing bootloader...
08:33:22.968: Error: Failed. Controller has returned to normal operation, please retry the operation.
08:33:23.218: Initializing bootloader, step 1 of 3
08:33:23.218: Error
08:33:23.218: Disconnecting ...
08:33:23.937: CAN-VPW Bridge Deactivated
08:33:23.937: Disconnected
08:34:30.734: Done!
this also pops up : bootloader Rejected Reason- controller has returned to normal operation please retry the operation
