Results 1 to 10 of 20
Thread: AutoCal Read List
    Nov 2007
    Default AutoCal Read List
    When I load Options.txt on my AutoCal it only shows the first two PCMs
    then copies the second one to the 3,4,5 spot. I don't understand ?
    this is what shows up
    Read 1
    E38
    Read 2
    E67
    Read 3
    E67
    Read 4
    E67
    Read 5
    E67
    even if I select
    E38
    E67
    LS1B
    T42
    T43
    Oct 2004
    Can you please email me (support@efilive.com) your Option.txt file?
    Andrew
    EFILive Crew
    Nov 2007
    Sent
    Oct 2004
    You're running the latest pre-release firmware right (2.07.06)? This issue didn't happen for me till I updated an AutoCal device this second. Once you confirm firmware for me I'll escalate it as a bug.
    Andrew
    EFILive Crew
    Nov 2007
    Correct. I ordered it from Justin, updated it and linked it up. I just wanted everything
    to be good before I handed it off to my customer.
    Thanx
    -Justin
    Oct 2004
    Thanks, I've escalated the issue mow. In the previous firmware there was only Read1 and Read2 options in Basic Menu Mode. The latest firmware has the 5 options so I'm thinking that the cause of the problem is simply going to be in the expansion of the number of Read options.
    Andrew
    EFILive Crew
    Nov 2007
    SOooo...... there is an Advanced Menu Mode ??
    Oct 2004
    Yup. In the device settings under Options. There is a selection for Simple or Advanced mode. I wou;dn't recommend sending it to a customer in Advanced Mode, there is just too much more "stuff" there and you support the customer remember
    Andrew
    EFILive Crew
    Nov 2007
    I tried Advanced mode and I got stuck in the scan tool menu <-Exit wouldn't work.
    I had to reboot to get out of it.
    Oct 2004
    The 'Exit' option in the Scan Tool menu section works fine for me in Advanced menu mode .
    Andrew
    EFILive Crew
  1. AutoCal?
    By Highlander in forum FlashScan V2
    Last Post: December 18th, 2008, 07:41 AM
  2. Autocal
    By Alvin in forum Lounge
    Last Post: August 1st, 2007, 01:55 PM
  3. Read posts in search...read tut..LM1 help.
    Last Post: March 15th, 2006, 02:00 PM
