Results 1 to 5 of 5
Thread: Wide band recommendation that plugs into V2
    Lifetime Member 68problemchild's Avatar
    Mar 2010
    Default Wide band recommendation that plugs into V2
    Hey guys. I just got the Wideband back for the second time from the manufacturer and still no go. Its the Innovate and still has two short flashes.
    V2 wont recognize it.
    What other widebands plug right into V2? What would you all recommend? I have given up trying to get this one working. I know the wiring is good since the regular O2 sensor works and reads just fine.
    Thanks in advance for all your help.
    Oct 2004
    I have 2 x LC-1's connected serially. If I was to purchase again I'd be having a look at a dual channel Tech Edge with NTK sensors I reckon.
    Andrew
    EFILive Crew
    Nov 2006
    How is your WBO2 wired and are the V2 settings correct for Innovate controllers?
    LC-1 WBO2
    Mar 2010
    Wiring is correct. Pos, Neg, High and low sensor. Pretty basic.
    On V2, I think I tried every possible configuration. Reg O2 works great.
    Will the tech edge plug right into V2? Any model number? best place to get one?
    THanks!
    Oct 2004
    You will need a serial cable to connect from the TechEdge to the V2 serial input. TAQuickness sells them (http://www.taquickness.com/taqcables.htm).
    I'm not aware of any TechEdge resellers. I think you'll just get them direct from Australia (http://wbo2.com/). Looks like either the '3B1 - Pro' or '3H1 - Dual' should work fine.
    Andrew
    EFILive Crew
  1. Dataloging Wide Band on PC
    By smithf71 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 26th, 2008, 06:30 AM
  2. Wide band
    By Harrismarine in forum FlashScan V2
    Last Post: July 6th, 2008, 12:27 PM
  3. The Wide Band....how do we really know...
    By Redline Motorsports in forum General
    Last Post: January 8th, 2007, 06:51 AM
  4. wide band o2
    By woody69 in forum Custom Operating Systems
    Last Post: October 23rd, 2006, 04:19 PM
  5. lm-1 wide band
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2006, 08:39 AM
