Hi all, long time user, first time poster.
I working on a 2005 LS6 car punched out to 7 liters and running a Harrop blower setup. We had previously tuned the car up to about 12 psi on the MAF but we were nearing the limits and the customer wanted more power so we converted to speed density using operating system 05120003. I have done speed density conversions before, but this is the first one on a high powered supercharged engine like this (previously torque was in excess of 700 lbs-ft).
After some issues with a faulty cam sensor, we got the car up and running properly on the SD map, but past about 3000 rpm at full throttle we get a hard cut and throttle disable. I've maxxed out the 6101 table, and no codes are being thrown other than some miscellaneous body and traction control items (car is a race car with many items removed), but these were all present on the MAF tune anyways. Car revs cleanly to limiter provided load doesn't get too high.
I suspect that I'm hitting some hard coded limit beyond the 6101 table. During my search here I found a post that mentioned rescaling some VE tables to fix the issue but couldn't find any more details. Can anyone shed some light on this (link or otherwise)? I'm assuming that reduction in VE in boost needs to be done to avoid freaking out the ECU and then recal the injectors to keep fueling appropriate.
I've attached a brief log (frames 485-495 are the relevant points where we went full throttle).
Again, to summarize - reduced power mode, no codes on EFILive Scan but OBD2 reset clears problem, using EFILive 7.5.6.
Thanks in advance.
Log_0039.efi
