Results 31 to 36 of 36
Thread: 04 Silverado turbo 6.0 help.
  1. #31
    Do you have a gauge...?
    Is there a way to connect using serial comms (see pic)...?
    You may have to swap/cross Tx and Rx.
Name:	PLX serial comms.png
  2. #32
    Jan 2011
    Genius! all I need to do is make one of these up And serial data! I will also need to change my calc_pids.txt back to {GM.EQIVRATIO}*{EXT.WO2LAM1} correct? In a previous post you said once I change my stotch to 9.8 I need to correct my commanded fuel. Can you elaborate or link me to more detail? As of right now Im WAY rich.
  3. #33
    More info from LC-1 perspective, see post #3: LC-1 serial comms
    You have to see if you need the null-modem/cross-over...
    If your PLX connects to a PC/laptop using a straight serial cable, then you need the null-modem/cross-over.
    If your PLX connects to a PC/laptop using a null modem serial cable, then you do not need the null-modem/cross-over.
    More info specifically on the PLX (is this the same model as your PLX...?): PLX serial comms upgrade
  4. #34
    Jan 2011
    Yes that is the same model I have. So it looks as tho I WILL need the null_modem/cross-over. Why couldn't i just eliminate the in between and just connect lc-1 jack to the rj12 connection with the proper pin out? Build my own cable. I have all the parts already......Just made up a cable cross fingers it works.
  5. #35
    Yes, build your own
  6. #36
    Jan 2011
    "No, you need to use a RS232 to TTL Converter.
    The data stream voltage needs converted...."
    found this in another thread...fml looks like need to convert te 5v down to 3.3 or something
  1. 2006 Silverado Turbo. . Really need a COS.
    By hotrod in forum Custom Operating Systems
    Last Post: January 25th, 2011, 12:54 PM
  2. Closing turbo vanes for turbo braking?
    By Haulinbass02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 14th, 2009, 12:12 PM
  3. turbo 5.3 silverado tuning
    By kostelacd69 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 2nd, 2009, 08:01 PM
  4. 06-07 Silverado SS
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 24th, 2006, 06:38 AM
  5. 06 silverado
    By HioSSilver in forum General (Petrol, Gas, Ethanol)
    Last Post: July 6th, 2006, 10:33 AM
