Ok, your calc_pids.txt does what we said.
My calc_pids is correct for a analog signal? It looked to me it was looking at serial?
04.05.efi
Oh, you're using analog...
Then in your calc_pids.txt file replace {EXT.WO2LAM1} with {CALC.AFR_PLX1}/14.7
Code:*CLC-00-110 factor 0.5 1.5 .4 "{GM.EQIVRATIO} * {EXT.WO2LAM1}"
Went through that idle tutorial last night just loaded it up and man what a difference Finally feel like im getting somewhere. Wanted to thank yall for the help.
Does your PLX report AFR based on 14.7 (it might be something else)...?
I think you are correct there websites says afr is calculated off of 14.7
So your PLX scales Lambda by internally multiplying it by 14.7, and this is what it reports via the analog connection which EFILive Scantool interprets as AFR.
So in your calc pids, you obtain Lambda by dividing the wideband AFR by 14.7 as in post #23.
So your CLC-00-110 should read:
Lambda is regardless of fuel used (this is why we try to avoid AFR).Code:*CLC-00-110 factor 0.5 1.5 .4 "{GM.EQIVRATIO} * {CALC.AFR_PLX1}/14.7"
Well the plx is cabable of outputing a lambda value instead of afr I just need to hook up one more wire.
http://www.plxdevices.com/Installati...UsersGuide.pdf
Let me have a read of that...
The good thing to do is to use serial comms to connect the PLX to V2... but I am not familiar with the PLX.
More info: showthread.php?7726-PLX-SM-AFR-Serial-upgrade&highlight=convert%20PLX%20serial
