Results 1 to 9 of 9
Thread: 2004.5 LLY EGR Block???'s
    Aug 2008
    Default 2004.5 LLY EGR Block???'s
    Did a EGR Delete kit on a 2004.5 LLY and with EFI Live turned off the DTC's P0401 thru P0406 & P1404 but truck goes into a kind of Limp Mode(no power 1-2lbs of Boost only) after a couple of minutes of driving. Is there anything else that has to be turned off or disabled. Diesel newbie
    Thanks in advance...
    FLASHSCAN V2 & AUTOCAL
    Nov 2006
    GAMEOVER,
    First off, I am new to all this too, but...
    Give this a try. Go to {B1506} EGR Maximum Percentage and {B1507} EGR Minimum Percentage and set all the values on the chart to zero. That may clear up your setting of codes.
    jc
    SIERRA 2500HD
    LLY - ZF6 - 4WD
    445hp/889tq
    Aug 2008
    Cool, will try it out and see what happens...
    Aug 2008
    Well I tried the settings above and now it will only Boost to 8-9lbs maximum and EGT's are over 800F...No DTC's or codes
    Feb 2011
    ok heres my problem....the truck revs up and maxs out at like 8-9 turbo psi but my egts are out the roof....truck ran fine till i installed an egr delete kit.....truck feels like its in limp mode but i have one code on start up 101 maf...
    Nov 2006
    You will not see a EGR code because you disabled the diagnostic code with C2401.
    I wonder if you may have a leak somewhere on your delete kit. Double check the up-pipes and the intake caps. I would say there is a leak on the intake side.
    jc
    SIERRA 2500HD
    LLY - ZF6 - 4WD
    445hp/889tq
    Aug 2008
    Thats what I was thinking....
    Feb 2011
    hey guys thanks for the input when i went back out there and looked the intake actaully popped out of the bridge....well installed it all ran like a champ but under real heavy load it pops back out....but i used so locking wire to hold in place till i can get a tac weld thanks for all your help,....ill be contacting sinister diesel to let them know to fix thier shit
    Nov 2006
    Good to hear. Hope you get it resolved.
    jc
    SIERRA 2500HD
    LLY - ZF6 - 4WD
    445hp/889tq
  1. Boot block, etc..
    By Chuck L. in forum FlashScan V2
    Last Post: January 29th, 2011, 07:04 AM
  2. 2004.5 LLY limping trans?
    By Mr.Blister007 in forum Duramax LLY
    Last Post: September 1st, 2010, 12:34 PM
  3. 2004 LLY Dual alternators
    By s10mods in forum Duramax LLY
    Last Post: March 29th, 2009, 01:45 PM
  4. Block size
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2004, 03:58 PM
