Results 11 to 20 of 30
Thread: E38 - Throttle Cut / Throttle Blip
  1. #11
    Jul 2007
    You can't keep the fuel and spark cut active indefinitely, this would stall the motor. The engine cut mechanism in the E38 allows for prolonged use of the clutch pedal without causing the motor to stall. For the purposes of a sequential gear change, I think it would be fine as the re-application of power is not a sudden burst. The spark is ramped back in progressively. I'm not sure if multiple triggers would help, it may, but it would need to occur in the time a normal shift would occur. I'd estimate that a shift should be over within 150mS to 500mS. If you look at the log I added, I was shifting between 225ms and 300ms, that was from clutch in to clutch out. So if the up shift event was to last longer than 500mS, there would be a problem.
    In the event of a missed gear, I doubt any race driver would want the GT to hold the engine cut on and risk a stalled motor. Instead they would probably know bout the missed gear in a very short period of time and reacted to the event. The E38 has a very good RPM limiter which will prevent over revving damage, so the driver can, if need be, resort back to manually clutching the gear change. What I would do is to test the GT setup and see what sort of time it takes for the shifts to occur, then tune the CFCO setting around these times. I would have this as part of my normal race preparation to ensure the shift speeds are catered for over the life of the gearbox. If a gear is missed for some reason in a race, it's then just a case of returning to manually changing, knowing the GT system cannot completely kill the motor.
    The idea of pulsing the signal may work but as you say, it needs testing. It would be fairly easy to try, just need a "555 timer" to switch the clutch pedal signal with say, a 5mS (200HZ) square wave. This in theory would repeat the spark and fuel cut until the engine RPM dropped to the CFCO min RPM speed at which point it would just act like a very low RPM rev limiter. Let me see if I can work something out.
    A quick touch on the idea of cutting power to the coils. In the E38, this would probably throw a bunch of miss-fire codes in the ECM as it detects that the cylinders are not firing. It would also throw a lot of raw intake charge down the exhaust, which would be very spectacular the next time the engine fired and the exhaust hit the unburnt mixture. So I wouldn't want to go this way with the car, unless you want to use exhaust flames to deter people from overtaking.....
    Simon
  2. #12
    Feb 2011
    You are right.
    The GCU apparantly if it detects things aren't working - reverts to a fixed period.
    So to summarize :
    1. Which wire/pin on the ECU is the Clutch Switch input
    2. What are the registers in the ECU that control the TReduction.
  3. #13
    Feb 2011
    Hi
    So what is the input pin on the E38 ECU which is the "clutch input" ?
    If using EFI Live to set the parameters ? which page or where to find the parameters ?
    Angus
  4. #14
    Jul 2007
    Hmmm, The first bit I'm not sure about. I'd need to find a wiring digram for the E38 with the pin labels. Maybe someone has one handy ?
    Tables:
    Put this in your "EFILive\V7.5\User Configuration\Scripts" directory and run it to turn on and set up the Clutch Fuel Cut Off tables. It should be a good start.
    E38_flat_shifts-ON.txt
    There is one issue though. If you keep your foot flat, then it may not activate, as the minimum throttle setting {B2426} can only got to 99.99%. However I think it'll be OK as mine seemed to still work.
    Simon.
  5. #15
    Feb 2011
    I have these...
  6. #16
    Feb 2011
ID:	11126Click image for larger version.
ID:	11127Click image for larger version.
ID:	11128Click image for larger version.
ID:	11129Click image for larger version.
  7. #17
    Feb 2011
  8. #18
    Feb 2011
    Hi
    So the minimum value for 'minimum throttle setting' is 99.99% ? A lower value is not setable ?
    Angus
  9. #19
    Jul 2007
    Minimum Throttle is the values that the throttle must be below for the CFCO settings to actually work. In my OS, the highest value that can be set is 99.998%, so not 100%. So in theory, you'd need to slightly lift of the throttle to cause the engine cut to enable. You may be able to affect the TPS sensor signal with the clutch switch though, dropping the indicated value to just under 99.9% and making the cut work. I dpon;t know if it would cause issues, but would probably work fine. Other OS's may allow higher values, I'm not sure.
    I also can't see any obvious details in the images you uploaded. However it might be that the clutch signal pin is using an abbreviation.
    Simon.
  10. #20
    Angus,
    Is that manual for a specific vehicle...? If so then turn to the engine wiring diagrams, you should see the clutch switch input...
    let me see if I can find a diagram for a C6...
  1. how to tune throttle follower and throttle cracker?
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 03:43 PM
  2. All I want is throttle % with F/I? HELP!
    By crosstheline in forum Gen III V8 Specific
    Last Post: March 11th, 2009, 03:33 PM
  3. E38 L76 without vss and MAF Throttle 30% Max
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: May 10th, 2008, 11:27 PM
  4. SLP 85mm MAF resistor, cut or not cut?
    By queso in forum General (Petrol, Gas, Ethanol)
    Last Post: October 9th, 2007, 12:50 PM
  5. Throttle blip...why is RPM slow to drop?
    By KAZ MotorSports in forum General (Petrol, Gas, Ethanol)
    Last Post: August 2nd, 2007, 08:28 AM
