Results 1 to 2 of 2
Thread: dsp 5 tune switch mix up
    Jan 2011
    Default dsp 5 tune switch mix up
    if you mix up the locating tab on the dsp switch can you mix up what positions the tunes are in?
    thanks for any help
    Jul 2004
    Turn the switch all the way clockwise, then put the tab in the 4th 5th hole so it only moves 4 clicks. Then it should be fine again.
    Ira
  1. dsp 2 switch not working on 01 lb7
    By mpeters0991 in forum Duramax LB7
    Last Post: January 7th, 2011, 08:38 AM
  2. loap tune on dsp5 switch
    By chevyrida06 in forum Diesel
    Last Post: October 23rd, 2010, 10:13 AM
  3. DSP switch components?
    By LBZoom in forum General (Diesel)
    Last Post: November 30th, 2009, 05:37 PM
  4. LMM DSP switch
    By GL4662 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 19th, 2009, 08:32 AM
  5. dsp switch install
    By numberoneshooter in forum Duramax LLY
    Last Post: April 27th, 2009, 02:46 PM
