Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: IAT is 39?
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Default IAT is 39?
    Ok, why is my scanning tool reading 39 degrees F when it is 83 F while I'm driving? Have I clicked the wrong PID or something? Having an IAT that low is probably great for not pulling timing but it's a lie and I'm sure the ECM knows that the IAT is at LEAST 83 because it is 83 here!
    2007 E38 Corvette
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Apr 2004
    I'm missing a post in here that suggested a broken wire.
    When I have this tune in the car, my IAT is an average 166F I am still using the same wires, IAT sensor but now I read a correct temperature. I am using the same PIDs. I must conclude that there is something wrong with the first tune I attached.
    Elmer
    Elmer, I saw that your log file shows what appears to be a valid IAT so it can't be a broken wire (IIRC broken wire gives something like -39°F).
    Apr 2004
    I only have 1 IAT PID to select? SAE.IAT
    It reads perfectly on the 2nd tune in post #2 but goes to shit on the first tune post #1.
    Apr 2004
    After further review, I see a 2nd IAT PID called IAT2. GM.IAT2
    IS that what I really need? The IAT PID works just fine on the 2nd tune I attached.
    Elmer, that is strange, I don't see how that could happen.
    Apr 2004
    Uh-oh. I think I'm in deep shit if you're stumped!
    Can you make this happen simply by flashing in the file from post #1...?
    Apr 2004
    Yep, absolutely every friggen time! That's what started this post! It's playing screw-screw with my mind!
    Apr 2004
    The second tune is an E-Force tune from Edelbrock that is scaled down by 25% It throws off my DIC instant gas mileage reading by 25% and the "Remaining Miles" is a total joke. The first tune is by my local tuner that is NOT scaled and gives my DIC readings correctly. I would prefer to use the 1st tune but something is wrong in the tune.
    Elmer
  1. IAT temps
    By Big Kahuna in forum Gen III V8 Specific
    Last Post: July 3rd, 2014, 02:17 AM
  2. IAT ???'s
    By GAMEOVER in forum E37, E38 & E67 PFI ECM's
    Last Post: August 20th, 2009, 07:14 PM
  3. Iat
    By Grey Silver in forum Gen III V8 Specific
    Last Post: August 4th, 2007, 01:56 PM
  4. IAT sensor
    By Chevy366 in forum Lounge
    Last Post: August 3rd, 2007, 11:49 AM
  5. IAT Placement
    By Lextech in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 13th, 2006, 03:49 PM
