Results 1 to 10 of 11
Thread: Where to buy repinning tools?
    Mar 2009
    Default Where to buy repinning tools?
    I've been to the site before, but I'm failing at the search and google tonight. Can anyone point me in the direction? I got my red and blue connectors at the junkyard, so now all I need is the tool to pin my 411 in place of my blackbox.
    Nov 2006
    LC-1 WBO2
    Mar 2009
    Crap, which one would I need?
    Aug 2010
    Hello Supercharged111,
    If you just want to remove the pins / wires from the 4 Vortec PCM connectors, and port them over to the 2 LS1-B style connectors (i.e. 0411 swap) - you really don’t require any special tools.
    The pins pull straight out the back of the connector, once you release the plastic locking tab on the other side - I generally use a small screwdriver and / or my fingers. If you first remove the Red and Blue pieces of plastic from the LS1-B connectors, the “locking” mechanism for the pins will become readily apparent. Same goes for the Vortec connectors (Blue / Red / Clear / Black).
    Installation is a simple “push to seat” exercise.
    Regards,
    Taz
    Feb 2006
    Also you might need a small sharp pick, like a thin ice pick. If you run across a location that did not have a previous terminal installed, to puncture through the rubber seal.
    Al
    Mar 2009
    Sounds like the Toyota connectors, how fragile are they? I'd hate to screw one up. The red/blue also requires the wires removed as I diked the harness in the junkyard though I couldn't care less about breaking the locks on the Vortec connectors. I ground a somewhat sharp end onto a paperclip to get into the smaller wires on my Toyota connectors to repin those. This is going to be a lot quicker than I thought, I just need to cough up $100 for a license and bang it out in 1 day. Sounds like I already have everything I need.
    Jul 2005
    www.eficonnection.com Mike has all the correct gm tools for sale. repin and crimp if you still need them.
    Lifetime Member Doc's Avatar
    Oct 2005
    Hey, freebie here: Next time you change your wiper blades save the metal backing shims. Couple sec on a grinder and you have a really fine point, strong tool custom to your application. That's about as "Green" as I get. LOL.
    www.efialchemy.com
    www.greatamericancarwar.com
    Nov 2007
    I just used the 45* pick from my Snap-On pick set. The 0411 PCM swap was the BEST thing I've done.
    That enabled my to use EFI Live's COS 5
    One day ?? I did mine on my lunch break.
    Nov 2007
    This Might Help 0411 Swap Article
  1. should I buy ?
    By conrodss in forum FlashScan V2
    Last Post: December 4th, 2010, 05:55 PM
  2. What to buy?
    By Sleeping in forum Purchase and Shipping
    Last Post: November 1st, 2010, 07:00 AM
  3. Dissasmbly tools
    By limited cv8r in forum CAX Files
    Last Post: February 6th, 2010, 08:33 AM
  4. i want to buy,but what should i get and for how much?
    By sand man in forum Purchase and Shipping
    Last Post: December 9th, 2009, 04:37 PM
  5. What to buy...
    By Macon@MMP in forum FlashScan V2
    Last Post: December 28th, 2006, 05:24 AM
