First of working on a 06 Corvette. When the scanner is hooked up with laptop and try and scan for DTC, it locks up the program. This is with ignition on and not running. I have tried it with the car running and it cut off and then locked up the program. If I disconnect the laptop then it will give the dtc and clear just fine.
Thanks in advance
Justin
