Results 1 to 6 of 6
Thread: E40 rev limit in neutral
    Aug 2007
    Default E40 rev limit in neutral
    Am I going blind, I can't find a rev limit in neutral in this tune, the car is converted(engine conversio into 4wd Nissan Patrol) I want to lower the rev limit and lowered all the rpm by gear but with no effect. The ECU dosen't know what gear the trans is in as it a manual.
    I think the ECM defaults to Park without a trans signal but I could be wrong. Do you have any wiring going into the ECM related to the trans?
    How do the factory VZs take care of the gear input?
    Aug 2007
    Yeah that's what I've found with the E38's but I can't see the rev limit in Park or Neutral
    Aug 2007
    The log says it is in gear 6. Still dosen't help much as I lowered all gears with no success
    Andrew should have sent the updated .calz file to you by now, please let us know if this fixes your problem.
    Oct 2004
    Yeah it would have been emailed by the EFILive Helpdesk yesterday afternoon local time. If you don;t have it shoot me an email (support@efilive.com) and I'll resend.
    Andrew
    EFILive Crew
  1. Replies: 6
    Last Post: January 2nd, 2011, 01:08 AM
  2. Weird E40 05 Vette rev limiter fix
    By 9secVette in forum Gen IV V8 Specific
    Last Post: August 11th, 2010, 03:07 AM
  3. Conquering Park/Neutral Signal and Gear Selector Switch (PNP)
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: May 29th, 2009, 11:53 PM
  4. HELP! can't keep off the rev-limit/fuel-cut
    By white2001s10 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 27th, 2007, 01:16 PM
  5. Can't get my truck to use the idle park/neutral tables
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: October 17th, 2005, 03:05 PM
