Help please
I cant tune my ecm. I have the latest software. Everytime i try to tune is goes through says ecm tune sucessfully but at the end of 15 sec it says permissison denied. What did i do wrong
EFILive Crew
Site Admin
If it is when you are attempting to save the calibration then it will be filesystem permissions on your laptop/pc. In that case try saving to the Desktop. Otherwise email me (support@efilive.com) a screenshot of the error if you can.
Andrew
EFILive Crew
here is what it says
18:15:45.813: Scanning for EFILive FlashScan V2 USB
18:15:45.829: Autodetect interface ...
18:15:47.623: Interface not detected
18:15:48.262: Scanning for EFILive FlashScan V2 HAPI
18:15:48.278: Autodetect interface ...
18:15:48.309: Interface firmware version: 2.7.4
18:15:48.325: Connection to [FSV2] interface is OK
18:15:48.340: Interface firmware model: FSV2
18:15:48.356: Interface firmware version: 2.7.4
18:15:48.372: Interface firmware date: Nov 30, 2010
18:15:48.387: FlashScan serial number: 003847606820
18:15:48.403: FlashScan license number: 003847606820
18:15:48.434: Disconnecting ...
18:15:48.840: CAN-VPW Bridge Deactivated
18:15:48.840: Disconnected
18:15:49.510: Scanning for EFILive FlashScan V2 USB
18:15:49.526: Autodetect interface ...
18:15:51.336: Interface not detected
18:15:51.975: Scanning for EFILive FlashScan V2 HAPI
18:15:51.991: Autodetect interface ...
18:15:52.225: Interface firmware version: 2.7.4
18:15:52.225: Connection to [FSV2] interface is OK
18:15:52.240: CAN-VPW Bridge Activated
18:15:52.318: Current protocol set to: "SAE J1850 VPW"
18:15:52.318: Autodetect PCM...
18:15:52.365: Connection to PCM is OK
18:15:52.365: Autodetect TCM...
18:15:52.412: Connection to TCM is OK
18:15:52.428: Current protocol: "SAE J1850 VPW"
18:15:52.662: Interface firmware model: FSV2
18:15:52.677: Interface firmware version: 2.7.4
18:15:52.693: Interface firmware date: Nov 30, 2010
18:15:52.708: FlashScan serial number: 003847606820
18:15:52.724: FlashScan license number: 003847606820
18:15:53.005: Getting status...
18:15:53.036: Status: OK.
18:15:53.785: Bootloader version: DLB7_v1.4F (08A6-B0BB)
18:15:53.800: Preparing ECM for reflash...
18:15:53.832: ECM seed is: $34BE
18:15:53.847: Unlock attempt 1 of 4
18:15:53.988: Initializing ECM...
18:15:54.783: Initializing ECM, step 1 of 4
18:15:54.783: Initializing ECM, step 2 of 4
18:15:55.579: Initializing ECM, step 3 of 4
18:15:55.579: Initializing ECM, step 4 of 4
18:15:56.031: Initializing bootloader...
18:15:56.437: Initializing bootloader, step 1 of 5
18:15:57.108: Initializing bootloader, step 2 of 5
18:15:57.778: Initializing bootloader, step 3 of 5
18:15:58.449: Initializing bootloader, step 4 of 5
18:15:59.120: Initializing bootloader, step 5 of 5
18:15:59.635: ECM ready for reflashing.
18:15:59.635: Request GM VIN...
18:15:59.713: VIN: 1GCHK23193F116201
18:16:00.384: Request serial number...
18:16:00.446: Serial number: 2227CT05MQ91
18:16:01.304: Request hardware number...
18:16:01.335: Hardware: 12209950
18:16:02.084: Intel AB28F400B - 512K
18:16:02.895: Attempting to reboot ECM... (please wait up to 8 seconds)
18:16:04.034: ECM has booted successfully...
18:16:05.048: Clear emisison related DTCs...
18:16:05.079: Clear DTCs for all modules...
18:16:05.376: Reflashing completed successfully
18:16:14.819: Done!
then it says can not create file c/program files/ 003847606820. ibu access is denied
EFILive Crew
Site Admin
Can you please change your User Access Control (UAC) settings as per this knowledgebase article?
The path should be C:\Program Files\EFILive\V7.5\...
Let me know if that makes a difference.
Andrew
EFILive Crew
Ok sorry for sounding dumb here. But how do i do that? Thanks
oh sorry. I got it. Ill let u know if it works
thank you
thank you very much. Got the truck tuned and its working great.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
