Results 1 to 4 of 4
Thread: dsp 5 help
    Feb 2011
    Default dsp 5 help
    I followed the instructions on the dsp tuning. I reflashed the computer and copied all my tunes into the dsp #1234. but when i tuned it my truck is still in the stock dsp and my switch doesnt work. Any help please.
    Feb 2011
    I have the switch hooked up right and everything. Do you have to do a full flash then when its done do another reg flash?
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Hey bud, are you positive you have the pins in the correct locations? Also, make sure they are ALL the way pushed in. Full flash once and then you can .cal flash after that.
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Feb 2011
    Oh no problems. I started over set up my tunes and flashed the ecm and it worked. Thanks for the help tho.
  1. help with DSP
    By justin123 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 22nd, 2009, 12:27 PM
  2. V2 DSP switching
    By musclecar400 in forum FlashScan V2 BB Logging
    Last Post: August 27th, 2009, 08:18 AM
  3. dsp os changes?
    By hot-dog in forum Diesel
    Last Post: April 27th, 2009, 09:25 AM
  4. dsp ??
    By tfkostecki in forum Duramax LB7
    Last Post: September 10th, 2008, 03:38 PM
