Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: March 05, 2011 release candidate 2
  1. #11
    The ABS is not even on the PCM's data bus in that model, weird.
  2. #12
    that what i thinking too.
    When i plug in the cable it does it (read and write to pcm)
    I plug in the cable and open V7.5 then turn on the ignition it goes through the system check and then the ABS Fault comes up on the digital dash screen.
    Try will the cable unplugged and turned on the ignition all good no ABS Fault
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
  3. #13
    Ah, that won't be a software thing. I can't remember which pin it is, but the old ALDL data bus (which the ABS is on) is also shared with another bus V2 talks on. It does seem very odd this would all of a sudden start to happen. We'll have to get Paul to check this out, though none of us have LS1 based Holden's any more.
  4. #14
    I haven't looked at a schematic, but doesn't the ABS module talk with the PCM across the bridge...?
  5. #15
    Yeah, there is a PIM module that converts the PCM's VPW to ALDL. Actually it's pretty sad that Holden were still using the ALDL bus on a 2004 model car!
    The ABS can actually cause a no start on the Commodore, they have a habit of going faulty and loading down the entire ALDL bus which means the BCM can't talk to the PIM for theft pass.
  6. #16
    just went out and try it on my car (2004 VY SS Series 2 Commodore) and it did not do it.
    maybe it's something different in the VY CX8 Advantra being all wheel drive
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
  7. #17
    didn't have a problem with this.
    i can start the car and it runs fine and the abs fault does not come up on the dash.
    the only time it does show is when the ignition is in the on position and engine not running.
    using the scan tool works and i can view live and record the log.
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
  8. #18
    Apr 2008
    minor comment, in case I need to switch between Eng or tranny ECU, it is written there right click on the picture, while I need to do a lift click.
    Regards,
    Odd Boy
  9. #19
    Oct 2004
    Quote Originally Posted by odd boy View Post
    Right-click is the only mouse operation that brings up the list for me. You're not left handed and have the mouse buttons switched do you?
    Andrew
    EFILive Crew
  10. #20
    Apr 2008
    no, i am right handed and buttons r on default settings.
    on the picture u wrote "right click" but it swaps when i click the lift button.
    Regards,
    Odd Boy
  1. February 26th 2011 release candidate 1
    Last Post: March 4th, 2011, 09:55 AM
  2. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
